Please, can anybody help me ? Brightness doesn't work on Acer Aspire 4741.
I use Ubuntu 14.10 x64. The screen is too bright and very painful for my eyes.
Are there any suggestions for me to get a solution?
cl-netbox
  • 31,491
Andhiku
Yes @ Karl is right Brightness option is directly associated with What type of Graphic Card you have & after New Installation Process, by default keeps this "off" (that is low high can't be done. If you have Intel Graphics then: (To check the graphic card)
type this in Terminal:
ls /sys/class/backlight/
If its Intel, the answer would be:
computer_mfg_name intel_backlight
Then try this:
Open Terminal & type this to create a config file:
sudo touch /usr/share/X11/xorg.conf.d/20-intel.conf
Now we need to edit this file. You can use any editor be it a terminal one or graphical.
sudo gedit /usr/share/X11/xorg.conf.d/20-intel.conf
Add the following lines to this file:
Section "Device"
        Identifier  "card0"
        Driver      "intel"
        Option      "Backlight"  "intel_backlight"
        BusID       "PCI:0:2:0"
EndSection
Save it. Restart the Computer. The brightness control should be working through function keys now.
Drp RD
  • 161
