If anyone has any suggestions or links, I'd be truly grateful. The brightness is not working, the screen stays at maximum brightness.
Thank you for your help. I followed the instructions from the link below and now the brightness adjustment works.
Jefe
See https://askubuntu.com/a/604913/50254
Basically, do following:
 sudo nano /usr/share/X11/xorg.conf.d/20-intel.conf
Add following lines
Section "Device"
        Identifier  "card0"
        Driver      "intel"
        Option      "Backlight"  "intel_backlight"
        BusID       "PCI:0:2:0"
EndSection
Save (CTRL+X) and reboot the system. Function keys plus arrows should now correctly adjust the backlight and you have 20 possible levels instead of only 4 levels supported by BIOS.
