Hello Ubuntu Community,
Yesterday I installed Ubuntu 14.04.1 LTS, because I got sound problems under Windows 8.0 and 8.1. The first Ubuntu Installation went wrong and the second try worked finally.
But later on I noticed that Ubuntu had only detected the headphones (wich were not connected) and not the internal Speakers. I also had that problem at Windows 8.0 and 8.1 and couldn`t figure out how to fix it. Now is the current Ubuntu Installation very unstable and freezes sometimes.
  1. Should I reinstall?
  2. If yes, should I try to install Linuxant HDA Drivers (Conexant HDA Driver)?
  3. Check or reinstall ALSA?
EDIT:
Thank you for your answer! What do you mean with MD5 Hashes and how can I execute them?
Output of "lsb_release -a":
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.2 LTS
Release: 14.04
Codename: trusty
EDIT 2:
Ubuntu freezed again and had to do an Alt+Ctrl+F1 and Alt+Ctrl+Del. Now I`m sure, that my installation was corrupt. Could you please tell me how to use these MD5 Hashes? And wich one should I pick? Now I noticed that I got two errors at boot, but they were shown too short (under 1s). Please help me!
Have you updated the system after installation? & After that look for the additional drivers in update settings.
Drp RD
  • 161
