I am trying to mount a Samba Shared Folder in Ubuntu, but I am facing some issues because when the folder is mounted, I have no permission to write on mounted folder.
First of all, the shared folder is on a server called vmfox and the folder's name is apps. On VMFox server, I have this samba configuration /etc/samba/smb.conf:
[global]
workgroup = MYDOMAINNAME
netbios name = vmfox
server string =
security = DOMAIN
encrypt passwords = true
obey pam restrictions = Yes
password server = server.mydomain.com.be
pam password change = Yes
passwd program = /usr/bin/passwd %u
passwd chat = *New*password* %n\n *Retype*new*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
unix password sync = Yes
log file = /var/log/samba/%m.log
max log size = 0
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
dns proxy = No
wins server = 201.232.023.10
kernel oplocks = No
NIS homedir = Yes
create mask = 0775
directory mask = 0775
printing = cups
oplocks = No
[apps]
path = /l/disk0/apps
valid users = myuser,otheruser
public = no
writable = yes
create mask = yes
force user = www-data
force group = www-data
So, with the configuration above I edited the file /etc/fstab on my local machine to mount the shared folder. First of all I created a file with my credentials: ~/.smbcredentials with the following content:
username=myusername
password=mypassowrd
And, finally, the file /etc/fstab with the following line:
//vmfox.example.com/apps /home/rgiaviti/Dev/Network/vmfox cifs credentials=/home/rgiaviti/.smbcredentials,iocharset=utf8,domain=MYDOMAINDOMAIN,file_mode=0777,dir_mode=0777 0 0
OK. After everything, the shared folder is mounted using sudo mount -a. The problem is, I have no write permission in the mounted folder. When I access this shared folder in a Windows Machine, I can write normally in this folder.
I used this guide to mount and this question helped me too, but no write permission at all.
