11
Have reinstalled Ubuntu on my web dev server. On the old one I had an smbfs share setup to access a share over the local network to other Ubuntu boxes. It was setup using the following and worked fine - http://ubuntuforums.org/showthread.php?t=288534
This time round I am using cifs-utils instead of smbfs, but I presume this is fine?
Upon reinstalling the server I have been having issues making the files writable. Its mounted ok, and when from my local machine I ls -l it shows me write permissions (although from my local user), but when I goto create or save over a file it gives me a no permissions error
Here is the line in my /etc/fstab. I had to make one change to be able to mount, and I added the ,sec=ntlmv2 option, without which I was getting mount error(13)
//192.168.0.40/webserver    /media/webserver        cifs    credentials=/root/.smbcredentials,sec=ntlmv2,iocharset=utf8,file_mode=0777,dir_mode=0777,uid=1000,gid=1000 0 0
and my credentials file (unchanged from when it was previously working)
username=melon
password=xxxxxxxxxxxx
How can I fix it so that I have write permissions on my mount?
Horse
  • 253
In my case solution was to add noperm option on the fstab entry
Make sure you have the following line in your /etc/samba/smb.conf file on the server:
writeable = yes
Hopefully that will enable write access to the share.
James
  • 156
As Mario Mastrorilli already mentioned form me the noperm option in the fstab worked. Here is the requested HowTo (David Foerster)
  1. Just open /etc/fstab:
     $> sudo nano /etc/fstab
  2. Add a line like that:
    //abc-fs/folder/  /media/mountpoint                 cifs    credentials=/root/.smbcredentials,iocharset=utf8,noperm       0       0
  3. Mount
    $> sudo mount -a
Bravehartk2
  • 131
In your server add following in file /etc/samb/samb.conf:
read only = no
hope this will work.
Eric Carvalho
  • 55,453
