details:
$ sudo apt-get install mercurial
Reading package lists... Done
Building dependency tree
mercurial is already the newest version.
mercurial set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo apt-get install tortoisehg
 tortoisehg : Depends: mercurial (< 2.9~) but 3.3.2-1ppa2~trusty1 is to be installed
              Recommends: python-iniparse but it is not going to be installed
any ideas/hints to get tortoisehg back in func?
thank you very much for amazingly well described troubleshooting on How do I resolve unmet dependencies after adding a PPA? however even after applying all major prescriptions with cleaning the databasei still get the same message.
One thing did happen: adding all sources did trigger update of many other packages - thanks for that
will research deeper
Lj MT
  • 149
Fixed.
  1. removed/disabled duplicates/all mercurial & tortoisehg ppa's from software update app.
  2. apt clean & update (following first hint & comments)
  3. installed python module for .ini files (useful to me anyhow)
  4. uninstalled existing mercurial 3.x using synaptic package manager
  5. installed tortoisehg from ubuntu software center (dependances autoselected)
steps 1,2 & 3 perhaps not necessary but recommended
tortoisehg now working, repos ok - readable/functional
post install:
$ hg --version
Mercurial Distributed SCM (version 3.0.1)
rerun software update, it claims no new updates available, will see how it'll behave on next software updates in future
credits to: dadexix86 & JohnnyEnglish
Lj MT
  • 149
