Found a really easy solution!
Create a file /etc/pm/sleep.d/70-check-recordings.
In this file check if a recording currently is active. If yes, just return exit 1. That's it. Suspend will be aborted.
My script looks like this, it is based on this at tvheadend.
$ cat /etc/pm/sleep.d/00-check-recordings
#!/bin/bash
# this script sets ACPI Wakeup alarm and stops standby if a recording is active
# safe_margin - minutes to start up system before the earliest timer
# bootup system x sec. before timer
safe_margin=60
# modify if different location for tvheadend dvr/log path
cd ~hts/.hts/tvheadend/dvr/log
start_date=0
stop_date=0
current_date=`date +%s`
for i in $( ls ); do
tmp_start=`cat $i | grep '"start":' | cut -f 2 -d " " | cut -f 1 -d ","`
tmp_stop=`cat $i | grep '"stop":' | cut -f 2 -d " " | cut -f 1 -d ","`
# logger "$0: $i from $(date -d @$tmp_start) to $(date -d @$tmp_stop)"
start_extra=`cat $i | grep '"start_extra":' | cut -f 2 -d " " | cut -f 1 -d ","`
stop_extra=`cat $i | grep '"stop_extra":' | cut -f 2 -d " " | cut -f 1 -d ","`
let tmp_start=$tmp_start-$start_extra*60
let tmp_stop=$tmp_stop+$stop_extra*60
# if recording is active, immediately stop suspend
# tmp_stop > now and tmp_start < now
if [ $((tmp_stop)) -gt $((current_date)) -a $((tmp_start)) -lt $((current_date)) ]; then
name=`grep -h -A 1 title $i | grep -v title | sed 's/.*: "\(.*\)"$/\1/'`
logger "$0: Currently RECORDING $name. No Suspend until $(date -d @$tmp_stop!)"
exit 1;
fi
# only check future recordings
# tmp_stop > now and tmp_start > now
if [ $((tmp_stop)) -gt $((current_date)) -a $((tmp_start)) -gt $((current_date)) ]; then
# take lower value (tmp_start or start_date)
# (start_date = 0) or (tmp_start < start_date)
if [ $((start_date)) -eq 0 -o $((tmp_start)) -lt $((start_date)) ]; then
start_date=$tmp_start
stop_date=$tmp_stop
fi
fi
done
wake_date=$((start_date-safe_margin))
# set up wakeup alarm
if [ $((start_date)) -ne 0 ]; then
logger "$0: Set Wakealarm for $name to $(date -d @$wake_date)"
echo 0 > /sys/class/rtc/rtc0/wakealarm
echo $wake_date > /sys/class/rtc/rtc0/wakealarm
fi
Now set up KDE to handle standby after time-out. If a recording is active, KDE standby is aborted by the above script.
See also this in the MythTV documentation.
