I am trying to setup Ubuntu guest OS on a Windows host system.After creating the new virtual machine, I am trying to install the guest additions and I am running sudo sh VBoxLinuxAdditions.run but running that I am getting the following error,
  The headers for the current running kernel were not found. If the following module compilation fails then this could be the reason.
  Building the shsared folder support module ... fail!
  Warning: Unknown version of the X window ystem installed. Not installing X Window system drivers.
Virtual box version : 4.3.4-91027
Host system : Windows 7 64 bit
Guest OS : Ubuntu 12.04 32 bit.
UPDATE
On newer version `4.3.26` it works fine, But I need to make it work on `4.3.4-91027`.
Thanks in advance.
Thushi
  • 131
That gives a clue. Install the headers for your kernel version:
sudo apt-get install linux-headers-`uname -r`
kos
  • 41,268
Try downgrading (Some issues have been addressed with the newer versions of VBox), make sure the versions correlate with the correct (Working) versions of VBox.
I found an hack for this problem, I just took the Guest additions of latest VirtualBox and I installed it.It solved all my problems. :)
Thank you
Thushi
  • 131
Instead of using the Virtualbox Guest Addition ISO file, try using the following commands in the terminal on the guest Virtual Machine :
Do update:
apt-get update
Install dependencies
apt-get install build-essential linux-headers-$(uname -r)
Install guest additions
apt-get install virtualbox-guest-x11
Use sudo before the commands if required.
pl_rock
  • 11,715
