43
I did the dd method and it wrote the iso to the USB drive, but I'm not sure that's all I have to do because it is Windows and may not have GRUB and I'm not sure so I'm asking the experts.
winusb does not work for Windows 10 so this is different from earlier questions.
Zanna
  • 72,312
8 Answers8
40
I tried all the ways in this thread and none worked (and seriously, the question is about specifically writing to an USB key, why would people propose copying the ISO to another partition instead ??).
The solution that did the trick for me (assuming your USB drive is /dev/sdc):
  • Run gparted
  • Create a new partition table on sdc, type msdos
  • Create a NTFS partition, set the boot flag on it
  • Extract the iso (can be done with 7z x windows10.iso)
  • Copy the content (via cp, rsync, a GUI, whatever) to the mounted NTFS partition (certainly /dev/sdc1)
  • The last, critical step, taken from this post : https://superuser.com/a/817656/248812 is :
    sudo ms-sys -7 /dev/sdc.
    ms-sys is available in a ppa : https://launchpad.net/~lenski/+archive/ubuntu/ms-sys
Without ms-sys, blinking cursor on boot when the USB key is inserted.
With it, windows logo shows up.
15
You don't need a USB, DVD or other external medium to install a Windows 10 Install Disk (ISO) starting from a Ubuntu only installation. It is possible to extract the image or ISO file to a partition of one your hard disks, preferable not the one your will use for a new Windows installation, and use it.
For the following steps, a working GRUB configuration should be present:
  1. Make sure you have a bootable and formatted NTFS partition present. Below, the partition will identified by (hd0,5) where hd0 is the containing hard disk with MSDOS or MBR partition table layout.
  2. Mounting the image will make it easier to extract it's contents. If Disk Image Mounter refuses to mount the iso file you can always use this command to mount any iso file:
    sudo mount -o loop [Image_Path] [Mount_Point]
  3. Copy the contents of new loop device to the NTFS partition.
  4. Now add a GRUB entry for Windows 10. This will make it possible for the bootloader GRUB to find install disk contained in the partition. Open /boot/grub/grub.cfg in text editor as root and add these lines
    menuentry 'Windows 10 Install Disk' {
    set root=(hd0,5)
    insmod part_msdos
    insmod ntfs
    insmod ntldr
    drivemap -s (hd0) ${root}
    ntldr /bootmgr
    change the root if needed, accordingly.
  5. Save and restart computer. Boot into the right item of your updated GRUB menu.
Watch this Youtube tutorial https://youtu.be/1Y4JXv9r5Ug
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Suman
  • 167
You can copy all the ISO contents to the flash drive and make it bootable.
So, first of all, install GParted from software center or from terminal:
sudo apt-get install gparted
Then, open it from dash or terminal:
gksudo gparted
After that, choose the flash drive from the menu in top right corner. There should be one partition. If you haven't any data to backup, reformat it as ntfs (bootmgr doesn't work right on fat32), click Apply (the tick in the header menu). Right-click the partition, choose Manage flags and check boot.
Then, you can mount it through your file manager (nautilus is default for GNOME and Unity).
Mount the ISO file:
sudo mount -o loop [path to iso] [mountpoint]
Then, you can copy all contents from the ISO mountpoint to the flash drive via the file manager.
Reboot your computer and set the USB Flash Drive to boot first.
Zanna
  • 72,312
aastefanov
  • 1,399
I managed to do this with WoeUSB. To install the WoeUSB command line tool snap package in all currently supported versions of Ubuntu open the terminal and type:
sudo snap install --edge woe-usb
sudo snap connect woe-usb:removable-media
To launch the woe-usb snap package command line tool run the following command:
/snap/bin/woe-usb.woeusb
If you get a permission denied error click the Permissions button on the woe-usb screen in Ubuntu Software and toggle the permissions options from OFF to ON as shown in the below screenshot.
woe-usb Permissions
karel
  • 122,292
  • 133
  • 301
  • 332
The ms-dos package is quite old an unmaintained. It does not load on ubuntu 16-04. Instead use the syslinux package which most likely already is installed: http://ubuntuhandbook.org/index.php/2013/08/repair-windows-mbr-from-ubuntu/
Also cp to an ntfs partition is slow. Extract the iso directly to sdc1
  • Run gparted
  • Copy the iso
    sudo dd of=/dev/sdc1 if=Win10_1703_English_x64.iso bs=4M
  • Create MBR
    sudo dd if=/usr/lib/syslinux/mbr/mbr.bin of=/dev/sdc
I tried with the ms-sys, it ran but I could not get the USB to boot. However, this worked:
sudo apt install woes
sudo woeusb --target-filesystem NTFS --device Win10.iso /dev/sdX
where the /dev/sdX must be your USB key.
If you weren't sure, then how can you say that the dd method worked? Also, that ain't the way. You have to use Rufus to make the USB drive bootable;not that I discourage the dd practices, since it is Windows we are talking about, I believe it is best to use Rufus to handle this for you.
If you have a Windows installation already, then boot into it and follow the steps below or else, use virtualbox.
PROCEDURE:
According to: http://www.cnet.com/how-to/how-to-install-windows-10-technical-preview-from-a-flash-drive/
you'll need at least 4GB flash drive (8GB for 64-bit).
--> Download and run Rufus, then insert your flash drive, making sure it doesn't contain any important data. (It's about to get wiped.) Rufus should automatically detect the drive and list it in the Device field. (If not, select the drive manually.)
--> Notice the check box marked, "Create a bootable disk using." Click the drive icon at the far right, then navigate to wherever you saved the Windows 10 ISO file. Select it, and then click Start. (All the other default settings in Rufus should be fine.)
--> This will take some time, perhaps as long as 20-30 minutes. Don't be alarmed (or confused) if an Explorer window appears for the flash drive; just leave it alone until Rufus reports "DONE." Then you can close the program and drive window and remove the drive.
--> Now it's time for the old PC. Plug the flash drive into a USB port, then power up the system. Most likely, it won't be configured to boot from an external drive by default, so you may need to jump into a startup menu or the BIOS during the POST. Ultimately, you need to force the machine to boot from the flash drive. Once you've done that, reboot, then follow the Windows installation instructions.
All the best!
Found a much easier solution. Mount the ISO with loop etc and -t udf. Copy everything in a spare NTFS partition. Mark this partition as boot in gparted. Run sudo update-grub and reboot.
Zanna
  • 72,312
d3rdon
  • 322
