I tried dual boot with Ubuntu and it deleted my window and i'm stuck with Ubuntu, i prefer windows over this and would like to factory reset my pc. If anyone know how and could help me please do!
If you didn't choose to install Ubuntu alongside Windows, then you're only option is to get a Windows media (a DVD or USB) and reinstall. There's no option for "factory reset" back to Windows once the Windows partition was completely removed.
If you go to the "Windows 10 ISO" download page from your Ubuntu computer (either Firefox or Chrome will do - and likely many other browsers, but it must be from Ubuntu, or else Microsoft will just redirect to to the EXE file), you'd be able to select and download an ISO image for Windows 10, after which you can use the Ubuntu DVD Creator to burn the ISO image to a blank DVD, assuming you have a DVD drive available.
If you don't have a DVD drive or blank discs to use, then you can write the downloaded ISO image to a USB drive - though that process is more complicated and requires to use a terminal to run some of the steps. Follow the process detailed in this Ask Ubuntu answer (please note that it is not the top voted answer - though you may need to read the top voted answer as well to help you copy the contents of the ISO image to the USB drive, as required).
Guss
  • 3,775
Don't panic. I always suggest to keep a Windows live USB as it saves the trouble when you mess up your system.
What you need here is a Windows live USB or DVD.
If you have access to another computer (yours or friends or family) you can download one. Boot from it and delete the partition where Linux is installed and install Windows on it, fresh.
abhishek
  • 2,696
