Today I installed Ubuntu on my Lenovo S20-30 and most things work but I can't use bluetooth. In the system preferences I can change the bluetooth switch to "on" but when I come back to the pane it is "off" again. Furthermore the bluetooth symbol is missing in the menubar, also the box in the pref pane is checked.
Since I'm completely new to the Linux world I don't know what more information you need for a diagnosis but here are some that maybe help:
$ dmesg | grep Bluetooth
[ 14.677429] Bluetooth: Core ver 2.19
[ 14.677466] Bluetooth: HCI device and connection manager initialized
[ 14.677477] Bluetooth: HCI socket layer initialized
[ 14.677481] Bluetooth: L2CAP socket layer initialized
[ 14.677497] Bluetooth: SCO socket layer initialized
[ 14.723428] Bluetooth: RFCOMM TTY layer initialized
[ 14.723443] Bluetooth: RFCOMM socket layer initialized
[ 14.723451] Bluetooth: RFCOMM ver 1.11
[ 15.038890] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.038895] Bluetooth: BNEP filters: protocol multicast
[ 15.038905] Bluetooth: BNEP socket layer initialized
and
$ sudo rfkill list
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: brcmwl-0: Wireless LAN
Soft blocked: no
Hard blocked: no
and
$ sudo lsmod | grep bluetooth
bluetooth 446409 10 bnep,rfcomm
6lowpan_iphc 18702 1 bluetooth
and
$ uname -a; lsusb
Linux tobis-lenovo 3.16.0-31-generic #43~14.04.1-Ubuntu SMP Tue Mar 10 20:13:38 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 004: ID 105b:e065
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 002: ID 5986:054a Acer, Inc
output form Jeremy31's script:
$ dmesg | tail -15
[ 18.881813] cfg80211: (5470000 KHz - 5725000 KHz @ 40000 KHz), (N/A, 2698 mBm), (0 s)
[ 18.881816] cfg80211: (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 22.074707] init: plymouth-upstart-bridge main process ended, respawning
[ 22.100053] init: plymouth-upstart-bridge main process ended, respawning
[ 45.348105] audit_printk_skb: 135 callbacks suppressed
[ 45.348111] audit: type=1400 audit(1427026413.699:72): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=2333 comm="apparmor_parser"
[ 45.348126] audit: type=1400 audit(1427026413.699:73): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=2333 comm="apparmor_parser"
[ 45.349128] audit: type=1400 audit(1427026413.699:74): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=2333 comm="apparmor_parser"
[ 154.979500] systemd-hostnamed[2562]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 1063.242591] systemd-hostnamed[8556]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 2549.195081] systemd-hostnamed[16264]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 2712.987102] usbcore: registered new interface driver btusb
[ 2713.065862] bluetooth hci0: Direct firmware load failed with error -2
[ 2713.065868] bluetooth hci0: Falling back to user helper
[ 2713.141987] Bluetooth: hci0: BCM: patch brcm/BCM43142A0-105b-e065.hcd not found
