SOLUTION: I was able to mount the partition and copy the files to another drive!
sudo fuseext2 -o ro -o allow_other /dev/mapper/vg1-lg1 /mnt
was the key. I still have not been able to access the files through nautilus, bit I've been able to copy the important stuff via the terminal.
I'm trying to mount a drive from a seagate central NAS using the 14.04 live USB to make sure the hardware is working before I turn this desktop into my new NAS. I found the partition with gparted - listed as /dev/sdb8, but I can't get it to mount. It has stuff on it (pictures/movies/etc) that I don't want to lose, so I don't want to just wipe it.
So far, I have tried to update/install lvm2 with apt-get - it tells me that is on the newest version. I have entered the UUID in fstab, and give it a mount point. Now when I run sudo mount /dev/sdb8, I get the message "mount: unknown filesystem type lvm2" (I get the same sort of thing when I tried changing the filesystem in fstab to lvm2_member.
I've tried changing a few things around and a re-occurring theme is the error message "missing codepage or helper program, or other error" it mentions a bad superblock on /dev/mapper/vg1-lv1.
If I can, I'll edit this in a moment with some terminal stuff. (Edited)
Hopefully somebody will be able to help me out with this, thank you in advance.
ubuntu@ubuntu:~$ sudo mount /dev/sdb8
mount: unknown filesystem type 'lvm2'
ubuntu@ubuntu:~$ sudo lvs
LV VG Attr LSize Pool Origin Data% Move Log Copy% Convert
lv1 vg1 -wi-a---- 1.81t
ubuntu@ubuntu:~$ sudo vgdisplay
--- Volume group ---
VG Name vg1
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 2
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 1
Open LV 0
Max PV 0
Cur PV 1
Act PV 1
VG Size 1.81 TiB
PE Size 4.00 MiB
Total PE 475641
Alloc PE / Size 475641 / 1.81 TiB
Free PE / Size 0 / 0
VG UUID UXroWv-R8vv-2p4f-CzTc-6fO2-gMRd-cvTsNJ
ubuntu@ubuntu:~$ sudo lvdisplay
--- Logical volume ---
LV Path /dev/vg1/lv1
LV Name lv1
VG Name vg1
LV UUID J6GHai-LQW1-kTqF-OkBQ-FaJm-t2cr-AEBbLq
LV Write Access read/write
LV Creation host, time ,
LV Status available
# open 0
LV Size 1.81 TiB
Current LE 475641
Segments 1
Allocation inherit
Read ahead sectors auto
- currently set to 256
Block device 252:0
ubuntu@ubuntu:~$ sudo lvscan
ACTIVE '/dev/vg1/lv1' [1.81 TiB] inherit
ubuntu@ubuntu:~$ ls /dev/mapper
control vg1-lv1
EDIT:
ubuntu@ubuntu:~$ sudo mount /dev/mapper/vg1-lv1 /mnt
mount: wrong fs type, bad option, bad superblock on /dev/mapper/vg1-lv1,
In some cases useful info is found in syslog - try
dmesg | tail or so
Output of sudo mount:
/cow on / type overlayfs (rw)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
/dev/sdc1 on /cdrom type vfat (rw,noatime,fmask=0022,dmask=0022,codepage=437,ioc
harset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/loop0 on /rofs type squashfs (ro,noatime)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
none on /run/user type tmpfs (rw,noexec,nosuid,nodev,size=104857600,mode=0755)
none on /sys/fs/pstore type pstore (rw)
systemd on /sys/fs/cgroup/systemd type cgroup(rw,noexec,nosuid,nodev,none,name=systemd)
gvfsd-fuse on /run/user/999/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=ubuntu)
output sudo fdisk -l
ubuntu@ubuntu:~$ sudo fdisk -l
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn
't support GPT. Use GNU Parted.
Disk /dev/sda: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sda1 1 3907029167 1953514583+ ee GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00180018
/dev/sdb1 * 63 625121279 312560608+ 7 HPFS/NTFS/exFAT
Disk /dev/mapper/vg1-lv1: 1995.0 GB, 1994982948864 bytes
255 heads, 63 sectors/track, 242542 cylinders, total 3896451072 sectors
Disk /dev/mapper/vg1-lv1 doesn't contain a valid partition table
Disk /dev/sdc: 7743 MB, 7743995904 bytes
80 heads, 16 sectors/track, 11816 cylinders, total 15124992 sectors
Disk identifier: 0x000ea421
/dev/sdc1 * 8064 15124991 7558464 b W95 FAT32
