I have just installed ubuntu 14.04 on my new thinkpad t450s. Everything basically works, but something is very flaky about my keyboard or display or both. After running for awhile some apps (E.g., thunderbird and sometimes emacs for example) will display garbage. If I refresh by moving the screen around or changing buffers/tabs/etc. they can often recover. (At this very moment my 7 key inserts a space into emacs. If save the file and look at the contents there is a 7 where I see a space in emacs. If I restart emacs, I can load the file see the 7 and press 7 and it works. Wierd. Not sure if it is related to the display issue.)
I see that there is an Intel(R) Graphics Installer for Linux* 1.0.7. I am leery about just loading this and running it. Any suggestions about how I should proceed?
$ sudo lshw -c video
  *-display
       description: VGA compatible controller
       product: Broadwell-U Integrated Graphics
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 09
       width: 64 bits
       clock: 33MHz
       capabilities: msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:63 memory:e0000000-e0ffffff memory:d0000000-dfffffff ioport:3000(size=64)
$ modinfo i915 | head
filename:       /lib/modules/3.16.0-31-generic/kernel/drivers/gpu/drm/i915/i915.ko
license:        GPL and additional rights
description:    Intel Graphics
author:         Tungsten Graphics, Inc.
srcversion:     9929027A8A6F05972AD6986
alias:          pci:v00008086d000022B3sv*sd*bc03sc*i*
alias:          pci:v00008086d000022B2sv*sd*bc03sc*i*
alias:          pci:v00008086d000022B1sv*sd*bc03sc*i*
alias:          pci:v00008086d000022B0sv*sd*bc03sc*i*
alias:          pci:v00008086d0000162Dsv*sd*bc03sc*i*
$ uname -a
Linux mypad 3.16.0-31-generic #43~14.04.1-Ubuntu SMP Tue Mar 10 20:13:38 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
What additional info do you need to see to help diagnosis this issue?
seth
  • 171
I had the same setup and was having all sort of problems with my display as well. The best solution I could find was to upgrade to the latest kernel. It is very easy and has solved numerous problems for me. Detailed information can be found here: How to update kernel to the latest mainline version without any Distro-upgrade?
