enter image description hereI am running ubuntu in text mode but it only fills 1/4 of my screen depending on what i choose in console-setup. I have changed grub to fit my needs but only the resolution changes, not the text size nor window. I have tried almost everything but can't seem to run our program in fulscreen mode. It is possible cause we are running it fullscreen on centos. any Ideas!
Have you installed an ubuntu-server 14.04 edition? Is that what you mean by "text mode"? If that's so, I will recommend you to see the following links:
Proper way to change terminal resolution in Ubuntu Server 13.04?
Maximum terminal resolution in ubuntu server virtual box guest
Changing resolution in Ubuntu Server 12.04
Hope it helps.
Rho
  • 1,244
