What happens to PPA and applications installed from PPA if Ubuntu is updated to the next release? Since Ubuntu-provided repositories are specific to Ubuntu releases, I'm guessing the same is for PPA? But only a URL for a PPA is provided--how do I know if the PPA is compatible with my Ubuntu release?
Essentially, what do I need to do in regard to PPA and applications installed from PPA when I update to the next Ubuntu release?
PPAs and other third-party repositories are disabled during a release upgrade. You have to manually enable them post-upgrade.
The packages are upgraded if a newer version exists, or left alone if there's no corresponding package in the official repositories.
You can visit the PPA page and check if it supports the newer release. In the Overview of published packages section, the Published in dropdown menu lists the releases for which packages are available.
muru
  • 207,228
Trusty and Utopic have this problem. Most PPAs have support for both. But what if you dont have a PPA that supports trusty but not Utopic, you would simply uninstall the application by typing in a Terminal
sudo apt-get autoremove packagename apt-get update
It is completely up to the maintainer if they wanted to support anything past Trusty.
In terms of how to remove PPAs sudo add-apt-repository --remove ppa:whatever/ppa
Also see this answer for PPA removals. It explains how to remove PPAs in other formats than just the Terminal command.
Virusboy
  • 1,566
