I'm a relative noob.
Trying to add WiFi Direct to my 12.04 installation on an old netbook. I was following this advice: How to get wifi direct( wifi p2p) on my HP DM1 laptop?
First, I downloaded wpa_supplicant-2.3 to the root and unpacked it
myself@myself-AspireOne:~$ tar -xzf wpa_supplicant-2.3.tar.gz
myself@myself-AspireOne:~$ cd wpa_supplicant-2.3/wpa_supplicant
Then I created a file called .config from info based at https://wireless.wiki.kernel.org/en/developers/p2p/howto and started the compilation.
myself@myself-AspireOne:~/wpa_supplicant-2.3/wpa_supplicant$ cp wpa_supplicant.conf /etc/wpa_supplicant.conf
cp: cannot create regular file `/etc/wpa_supplicant.conf': Permission denied
myself@myself-AspireOne:~/wpa_supplicant-2.3/wpa_supplicant$ sudo cp wpa_supplicant.conf /etc/wpa_supplicant.conf
[sudo] password for myself:
myself@myself-AspireOne:~/wpa_supplicant-2.3/wpa_supplicant$ sudo make && make install
  CC  config.c
  CC  notify.c
  CC  bss.c
  CC  eap_register.c
  CC  ../src/utils/common.c
  CC  ../src/utils/wpa_debug.c
  CC  ../src/utils/wpabuf.c
  CC  ../src/utils/os_unix.c
  CC  ../src/utils/eloop.c
  CC  config_file.c
  CC  ../src/rsn_supp/wpa.c
  CC  ../src/rsn_supp/preauth.c
  CC  ../src/rsn_supp/pmksa_cache.c
  CC  ../src/rsn_supp/peerkey.c
  CC  ../src/rsn_supp/wpa_ie.c
  CC  ../src/common/wpa_common.c
  CC  p2p_supplicant.c
  CC  ../src/p2p/p2p.c
  CC  ../src/p2p/p2p_utils.c
  CC  ../src/p2p/p2p_parse.c
  CC  ../src/p2p/p2p_build.c
  CC  ../src/p2p/p2p_go_neg.c
  CC  ../src/p2p/p2p_sd.c
  CC  ../src/p2p/p2p_pd.c
  CC  ../src/p2p/p2p_invitation.c
  CC  ../src/p2p/p2p_dev_disc.c
  CC  ../src/p2p/p2p_group.c
  CC  ../src/ap/p2p_hostapd.c
  CC  ../src/utils/bitfield.c
  CC  ../src/eap_peer/eap_tls.c
  CC  ../src/eap_peer/eap_peap.c
  CC  ../src/eap_common/eap_peap_common.c
  CC  ../src/eap_peer/eap_ttls.c
  CC  ../src/eap_peer/eap_md5.c
  CC  ../src/eap_peer/eap_mschapv2.c
  CC  ../src/eap_peer/mschapv2.c
  CC  ../src/eap_peer/eap_gtc.c
  CC  ../src/eap_peer/eap_otp.c
  CC  ../src/eap_peer/eap_leap.c
  CC  wps_supplicant.c
  CC  ../src/utils/uuid.c
  CC  ../src/eap_peer/eap_wsc.c
  CC  ../src/eap_common/eap_wsc_common.c
  CC  ../src/wps/wps.c
  CC  ../src/wps/wps_common.c
  CC  ../src/wps/wps_attr_parse.c
  CC  ../src/wps/wps_attr_build.c
  CC  ../src/wps/wps_attr_process.c
  CC  ../src/wps/wps_dev_attr.c
  CC  ../src/wps/wps_enrollee.c
  CC  ../src/wps/wps_registrar.c
  CC  ../src/eapol_supp/eapol_supp_sm.c
  CC  ../src/eap_peer/eap.c
  CC  ../src/eap_peer/eap_methods.c
  CC  ap.c
  CC  ../src/ap/hostapd.c
  CC  ../src/ap/wpa_auth_glue.c
  CC  ../src/ap/utils.c
  CC  ../src/ap/authsrv.c
  CC  ../src/ap/ap_config.c
  CC  ../src/utils/ip_addr.c
  CC  ../src/ap/sta_info.c
  CC  ../src/ap/tkip_countermeasures.c
  CC  ../src/ap/ap_mlme.c
  CC  ../src/ap/ieee802_1x.c
  CC  ../src/eapol_auth/eapol_auth_sm.c
  CC  ../src/ap/ieee802_11_auth.c
  CC  ../src/ap/ieee802_11_shared.c
  CC  ../src/ap/drv_callbacks.c
  CC  ../src/ap/ap_drv_ops.c
  CC  ../src/ap/beacon.c
  CC  ../src/ap/eap_user_db.c
  CC  ../src/ap/ctrl_iface_ap.c
  CC  ../src/eap_server/eap_server.c
  CC  ../src/eap_server/eap_server_identity.c
  CC  ../src/eap_server/eap_server_methods.c
  CC  ../src/ap/wmm.c
  CC  ../src/ap/ap_list.c
  CC  ../src/ap/ieee802_11.c
  CC  ../src/ap/hw_features.c
  CC  ../src/ap/dfs.c
  CC  ../src/ap/wps_hostapd.c
  CC  ../src/eap_server/eap_server_wsc.c
  CC  ../src/ap/wpa_auth.c
  CC  ../src/ap/wpa_auth_ie.c
  CC  ../src/ap/pmksa_cache_auth.c
  CC  ../src/ap/peerkey_auth.c
  CC  ../src/crypto/ms_funcs.c
All goes nicely until: The compilation eventually hits a snag.
  CC  ../src/eap_common/chap.c
  CC  ../src/eap_peer/eap_tls_common.c
../src/crypto/tls_openssl.c:19:25: fatal error: openssl/ssl.h: No such file or directory
compilation terminated.
make: *** [../src/crypto/tls_openssl.o] Error 1
Can anyone tell me what exactly is missing, why and how to fix it, using instructions that don't assume a lot of knowledge. This is my first use of the make command.
Thanks for helping a Noob.
Also, any suggestions if wpa_gui is safe to use; it asks for system password when ran.
Little me
  • 115
I was able to get it to compile with the help of a couple google searches on the specific errors. The one you got fatal error: openssl/ssl.h: No such file or directory compilation terminated. and the one I got fatal error: netlink/genl/genl.h: No such file or directory compilation terminated after getting past the first one. The upshot is I installed libnl1, libssl-dev and libnl-dev. Use the following command to install them
sudo apt-get install libnl1 libssl-dev libnl-dev
Following that run your make && make install as usual
Note: For the .config I used the one in the archive and just uncommented the lines related to WiFi-Direct rather than the sample pointed to here This compiled fine on Ubuntu 14.04
Elder Geek
  • 36,752
