12
I am an Ubuntu newbie. I have a HP DM1 laptop with Ralink RT5390 wifi card. It has the ability to connect on wifi direct with my Nexus 7 in Windows while using latest drivers located at Mediatek site. But I am unable to use wifi direct in Ubuntu. I found wpa2_supplicant supports this and installed the same, but still wifi direct is not functioning.
Can anyone help?
jeshurun
  • 838
You have to compile and install wpa_supplicant (see http://www.ab9il.net/linuxwireless/wpa_supplicant.html) and before compiling edit the ".config" file as in http://wireless.kernel.org/en/developers/p2p/howto .
Now use wpa_cli commands (see http://processors.wiki.ti.com/index.php/OMAP_Wireless_Connectivity_NLCP_WiFi_Direct_Configuration_Scripts and http://svn.dd-wrt.com/browser/src/router/hostapd-wps/wpa_supplicant/README-P2P?rev=16495)
Hope it helps
EDIT: If you get errors in Ubuntu 14.04 during the compile like: fatal error: openssl/ssl.h: No such file or directory compilation terminated. and fatal error: netlink/genl/genl.h: No such file or directory compilation terminated you may need to install libnl1, libssl-dev and libnl-dev. Use the following command to install them
sudo apt-get install libnl1 libssl-dev libnl-dev
Elder Geek
  • 36,752
cgv
  • 160
