I am in the process of wiping my Windows 8.1 install and replace it with Ubuntu 14.04 LTS, but have the following queries pls, prior to doing anything:
1) Will I be able to install Ubuntu 14.04 LTS on my new Acer Aspire ES1-512 C32A laptop, which is a 64 bit OS, has 8GB RAM (upgraded it) and a 500GB HDD (7200rpm). Boot mode is set to: UEFI?
2) I have created a USB Flash drive install of Ubuntu using Universal Installer app - I believe it worked, even though it was stuck on 99% but when I pressed "Close" after 15 mins, it came back saying installation completed successfully - can I assumed this worked or can people suggest another installer ISO app?
3) When I restart my laptop and press the F2 key to enter BIOS mode, I switch over to Boot section and I am presented with Boot Mode of UEFI and then the option set boot sequence of drives, which would be my USB drive. My question is, what should the Boot Mode be when I go to change the boot order sequence - should it be UEFI or Legacy?
4) If/when I eventually wipe Windows 8.1 and replace with Ubuntu, is there any special I need to do from my end?
5)Will things like Wireless LAN | SD Card Reader| Touchpad work straight off the bat or do I need to install specific drivers?
Have I missed any other crucial steps?
Furthermore, I actually have another laptop that I use for all things Windows 8.1 and so I want to dedicate this Acer laptop alone to just being a linux box. Am not interested in dual boot on Acer.
Thanks.
tonyf
  • 2,637
Many users find one application or game that they just cannot live without and then want to restore Windows & dual boot. Best to have good backups of efi partition and full Windows install.
How you boot install media UEFI or CSM/BIOS is how it installs. And then that is the setting you have to have in UEFI. Best to use UEFI.
Acer Aspire ES1-512-C39M Details on password and settings to enable trust on ubuntu entries
http://ubuntuforums.org/showthread.php?t=2256083&p=13203044#post13203044
http://acer--uk.custhelp.com/app/answers/detail/a_id/27071/~/how-to-enable-or-disable-secure-boot
Aspire E1-522 InsydeH20 Bios unlock - 7 min video https://www.youtube.com/watch?v=7SkBFkzOW0A
Acer E1-531 UEFI menus. http://www.tomshardware.com/forum/65627-63-body
Did live installer work in live mode? That tells best if it will work without added effort to install extra/special drivers.
oldfred
  • 12,583
  • first of all, you need to be sure that you have the 64 bit Ubuntu installer and not the 32 bit. You can get it at
http://releases.ubuntu.com/14.04/
http://releases.ubuntu.com/14.04/ubuntu-14.04-desktop-amd64.iso
  • next, you have to make a live usb of ubuntu:
http://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
  • then, change the IDE to your flash drive and boot from it
  • then, install Ubuntu alongside windows.
  • if you have problems with your partitioning, pick "try Ubuntu" in the beggining of your installation and open gparted partition editor. then, check and fix the windows partition.
  • if you get all this done, you should have grub and dual-boot on your computer
Note: if my answer solved your problem, dont forget to tick the check mark next to the answer.
ENJOY!
Jorge Castro
  • 73,717
belay neh
  • 108
i think you have to install ubuntu inside windows8.1 and make your PC dual boot thats will help you to do any thing in both system
you can see here : Dual-Boot Ubuntu 14.04 and Windows 8 "2014"
First Go to Installing Ubuntu Alongside a Pre-Installed Windows with UEFI and read everything very carefully. Even though the answers are for dualboot, you can choose to wipe Windows and replace it with Ubuntu at the time of installation.
To answer your questions...
This is hard to say as computer manufacturers often use different internal components for different batches of the computer with same model number. The best thing to do is to boot from the Live USB you created and select "Try Ubuntu without installing". This option will not make any changes to your computer and you will be able to check if everything works or not.
Try the Live USB without installing as mentioned above. If it does not work, try creating the Live USB again.
For a system that just boots Ubuntu, it does not matter if you choose UEFI or Legacy. The installation program will use the appropriate process. If you intend to use UEFI, at the time you choose the Boot drive, make sure you choose the USB with UEFI.
If you select the option to replace Windows with Ubuntu during installation, it will erase everything in your hard drive including other partitions such as D:\. If you have data, music, photos, etc. in another partition, copy them in an external drive before you start. You may also choose "Something Else..." and manually select the partitions for Ubuntu. This requires some knowledge of the partition scheme used by Ubuntu.
Most things should work. Ubuntu has most drivers already built in. The two exceptions are graphics cards and WiFi cards. Even for these opensource drivers are built-in. If your WiFi card needs a proprietary driver, you connect your computer by Ethernet during installation and check the appropriate box to install these additional drivers at the install time. This can be also done later by running the appropriate program that looks for and installs additional drivers if they are needed.
Hope this helps
user68186
  • 37,461
