Is there a good image editor application for Ubuntu with which I can convert jpg/png images into WebP format? ImageMagick was a crap for me! With it, output webp image's size just increased!!!
There is a plugin for the Gimp that provides the ability to load and export WebP images. You can install the package (gimp-webp) from this PPA:
ppa:george-edison55/webp
(Click here for instructions on using PPAs.)
The commands for doing this would be:
sudo add-apt-repository ppa:george-edison55/webp
sudo apt-get update
sudo apt-get install gimp-webp
Once the package is installed, open up the Gimp and you will now be able to export images to the WebP format:
The package is currently available for Trusty, Utopic, Vivid, and Wily.
Disclaimer: I am the author of the plugin.
- 32,495
16.04 Fixed
Since 16.04 imagemagick (or convert) does support webp, although it delegates to webp, so you need to install webp.
sudo apt-get install webp
But importantly things like convert img.png img.webp do work now.
Before 16.04 convert simply gave a png or jpg as output. The result wasn't a webp format. (You probably got bigger filesizes because it converted jpg with default (higher) quality)
Thumbnails:
display 'vid:*.webp'
- 6,035
There is a webp package in Software Center by which you can convert GIF to WebP via commandline.
Also there's a paint for KDE, KolourPaint, which can save images as WebP.
- 5,974
Achieved using CLI
Windows:
> for /R . %I in (*.jpg) do ( cwebp.exe %I -o %~fnI.webp )
Linux / macOS:
$ for F in *.jpg; do cwebp $F -o `basename ${F%.jpg}`.webp; done
Note: replace .jpg with .png if PNG is what you are dealing with.
Source: Google Devs FAQs
- 141
