-5
It has been hard for me, following directions I can find online on the Ubuntu sites and others, how to simply get 14.04 LTS loaded on to a Windows laptop.
I want to get remove Windows 7 on the laptop and replace with 14.04. I'm looking for step by step directions.
I found a download button, nothing more than that. What do you do with the download once you get on your desktop.
Then I went to another directions page, and it says download from a DVD. How do I get it on the DVD? How do I use it from a memory stick, it is all I have.
Mateo
  • 8,152
First step calm down. You will not get what you want by shouting out your problem (YOUR USING ALL CAPS), in fact you will probably get ignored, more then likely you don't have your BIOS configured properly to boot a USB drive to install Ubuntu, set that up first then try loading it. Just a suggestion maybe try testing out Ubuntu first before installing, unless you have tested it before and you know what your expecting. Also make sure you backup all your music files, video files and documents that you can't afford to lose as Linux uses a different file system (ex4) then Windows (NTFS) so in the process of installing it will format your hard drive and you will not be able to restore it.
