22
When running the command today:
sudo clamscan -r --detect-pua / > clamscan1.txt
I got very many errors going along the lines of these ones (in the txt file):
/sys/fs/ecryptfs/version: Can't read file ERROR
/sys/fs/ext4/sda1/inode_readahead_blks: Can't read file ERROR
/sys/fs/ext4/sda1/mb_max_to_scan: Can't read file ERROR
/sys/fs/ext4/sda1/msg_ratelimit_burst: Can't read file ERROR
/sys/fs/ext4/sda1/delayed_allocation_blocks: Can't read file ERROR
/sys/fs/ext4/sda1/max_writeback_mb_bump: Can't read file ERROR
/sys/fs/ext4/sda1/mb_stream_req: Can't read file ERROR
/sys/fs/ext4/sda1/mb_min_to_scan: Can't read file ERROR
/sys/fs/ext4/sda1/mb_stats: Can't read file ERROR
/sys/fs/ext4/sda1/err_ratelimit_burst: Can't read file ERROR
/sys/fs/ext4/sda1/session_write_kbytes: Can't read file ERROR
/sys/fs/ext4/sda1/lifetime_write_kbytes: Can't read file ERROR
/sys/fs/ext4/sda1/mb_group_prealloc: Can't read file ERROR
/sys/fs/ext4/sda1/inode_goal: Can't read file ERROR
/sys/fs/ext4/sda1/reserved_clusters: Can't read file ERROR
/sys/fs/ext4/sda1/extent_max_zeroout_kb: Can't read file ERROR
/sys/fs/ext4/sda1/err_ratelimit_interval_ms: Can't read file ERROR
/sys/fs/ext4/sda1/warning_ratelimit_burst: Can't read file ERROR
/sys/fs/ext4/sda1/warning_ratelimit_interval_ms: Can't read file ERROR
/sys/fs/ext4/sda1/mb_order2_req: Can't read file ERROR
/sys/fs/ext4/sda1/msg_ratelimit_interval_ms: Can't read file ERROR
/sys/fs/ext4/features/meta_bg_resize: Can't read file ERROR
/sys/fs/ext4/features/batched_discard: Can't read file ERROR
/sys/fs/ext4/features/lazy_itable_init: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/taint: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/initstate: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/coresize: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.init.text: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.smp_locks: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.data: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.text: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/__mcount_loc: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.rodata: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/__verbose: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.strtab: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.symtab: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.gnu.linkonce.this_module: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.rodata.str1.1: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.rodata.str1.8: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.note.gnu.build-id: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.exit.text: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/sections/.data..read_mostly: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/refcnt: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/initsize: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/taint: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/initstate: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/coresize: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.init.text: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.smp_locks: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.data: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.text: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/__param: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/__mcount_loc: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.rodata: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/__verbose: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.strtab: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.symtab: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.gnu.linkonce.this_module: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.rodata.str1.1: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.rodata.str1.8: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.note.gnu.build-id: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.exit.text: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/sections/.data..read_mostly: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/parameters/hashsize: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/refcnt: Can't read file ERROR
/sys/module/nf_conntrack_ipv4/initsize: Can't read file ERROR
/sys/module/nf_conntrack_ipv6/srcversion: Can't read file ERROR
And in the Terminal window I got lots of errors such as these ones:
LibClamAV Warning: fmap_readpage: pread fail: asked for 4077 bytes @ offset 19, got 0
LibClamAV Warning: fmap_readpage: pread fail: asked for 4094 bytes @ offset 2, got 0
WARNING: Can't open file /sys/module/videobuf2_memops/uevent: Permission denied
LibClamAV Warning: fmap_readpage: pread fail: asked for 4092 bytes @ offset 4, got 0
WARNING: Can't open file /sys/module/keyboard/uevent: Permission denied
LibClamAV Warning: fmap_readpage: pread fail: asked for 4090 bytes @ offset 6, got 0
WARNING: Can't open file /sys/module/kgdb_nmi/uevent: Permission denied
WARNING: Can't open file /sys/module/virtio_mmio/uevent: Permission denied
WARNING: Can't open file /sys/module/xhci_hcd/uevent: Permission denied
LibClamAV Warning: fmap_readpage: pread fail: asked for 4072 bytes @ offset 24, got 0
LibClamAV Warning: fmap_readpage: pread fail: asked for 4095 bytes @ offset 1, got 0
LibClamAV Warning: fmap_readpage: pread fail: asked for 4091 bytes @ offset 5, got 0
WARNING: Can't open file /sys/module/6lowpan_iphc/uevent: Permission denied
WARNING: Can't open file /sys/module/ip6_tables/uevent: Permission denied
WARNING: Can't open file /sys/module/xt_addrtype/uevent: Permission denied
WARNING: Can't open file /sys/module/pci_hotplug/uevent: Permission denied
WARNING: Can't open file /sys/module/ip6t_REJECT/uevent: Permission denied
WARNING: Can't open file /sys/module/x86_pkg_temp_thermal/uevent: Permission denied
WARNING: Can't open file /sys/module/debug_core/uevent: Permission denied
WARNING: Can't open file /sys/module/snd_seq_midi/uevent: Permission denied
WARNING: Can't open file /sys/module/crc32_pclmul/uevent: Permission denied
LibClamAV Warning: fmap_readpage: pread fail: asked for 4089 bytes @ offset 7, got 0
WARNING: Can't open file /sys/module/psmouse/uevent: Permission denied
WARNING: Can't open file /sys/module/nf_conntrack_ipv4/uevent: Permission denied
WARNING: Can't open file /sys/module/nf_conntrack_ipv6/uevent: Permission denied
Is this anything to worry about?
OS Information:
Description:    Ubuntu 14.10
Release:    14.10
Package Information:
clamav:
  Installed: 0.98.6+dfsg-0ubuntu0.14.10.1
  Candidate: 0.98.6+dfsg-0ubuntu0.14.10.1
  Version table:
 *** 0.98.6+dfsg-0ubuntu0.14.10.1 0
        500 http://gb.archive.ubuntu.com/ubuntu/ utopic-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu/ utopic-security/main amd64 Packages
        100 /var/lib/dpkg/status
     0.98.4+dfsg-2 0
        500 http://gb.archive.ubuntu.com/ubuntu/ utopic/main amd64 Packages
terdon
  • 104,119
/sys is the mount point of a sysfs virtual file system:
sysfs is a virtual file system provided by the Linux kernel. By using virtual files, sysfs exports information about various kernel subsystems, hardware devices and associated device drivers from the kernel's device model to user space. In addition to providing information about various devices and kernel subsystems, exported virtual files are also used for their configuring.
The files in /sys are not real files, viruses will not infect them. Also, you can't create new files inside /sys, try it yourself! There's no need to scan it. Use the command line option --exclude-dir="^/sys" to ignore /sys.
Eric Carvalho
  • 55,453
