I just bought an Dell XPS 13 2015 (9343) whose Linux (installed Ubuntu 14.04 LTS (Trusty Tahr)) support seems to be quite disappointing at the moment. Before spending money on new equipment I would like to be sure about some functions.
  • The XPS has an Displayport 1.2 which should support Multi Stream Transport (MST). Ubuntu in general does as well. The question is now, if Ubuntu supports it in combination with the XPS' Intel HD5500? Any experiences here? Great would be Daisychaining as well.
It would be great to here your experiences and tips with this or similar models.
EDIT: Here is the lshw output:
Beschreibung:  VGA compatible controller
Produkt:  Broadwell-U Integrated Graphics
Hersteller:  Intel Corporation
Physische ID:  2
Bus-Informationen:
pci@0000:00:02.0
Version:  09
Breite:  64 bits
Takt:  33MHz
Fähigkeiten:  msi pm vga_controller bus_master cap_list rom
Konfiguration:
driver = i915
latency = 0
Ressourcen:
irq : 64
memory : f6000000-f6ffffff
memory : e0000000-efffffff
ioport : f000(Größe=64)
Here is the modinfo i915 output:
filename:       /lib/modules/3.16.0-30-generic/kernel/drivers/gpu/drm/i915/i915.ko
license:        GPL and additional rights
description:    Intel Graphics
author:         Tungsten Graphics, Inc.
srcversion:     3E1094D0573592892C2C238
alias:          pci:v00008086d000022B3sv*sd*bc03sc*i*
... many more alias ...
depends:        drm_kms_helper,drm,video,i2c-algo-bit
intree:         Y
vermagic:       3.16.0-30-generic SMP mod_unload modversions
signer:         Magrathea: Glacier signing key
sig_key:        7B:E2:A7:20:0F:17:F0:0C:A0:11:F7:0E:5A:87:4C:37:E3:E0:F6:BE
sig_hashalgo:   sha512
parm:           modeset:Use kernel modesetting [KMS] (0=DRM_I915_KMS from .config, 1=on, -1=force vga console preference [default]) (int)
parm:           panel_ignore_lid:Override lid status (0=autodetect, 1=autodetect disabled [default], -1=force lid closed, -2=force lid open) (int)
parm:           powersave:Enable powersavings, fbc, downclocking, etc. (default: true) (int)
parm:           semaphores:Use semaphores for inter-ring sync (default: -1 (use per-chip defaults)) (int)
parm:           enable_rc6:Enable power-saving render C-state 6. Different stages can be selected via bitmask values (0 = disable; 1 = enable rc6; 2 = enable deep rc6; 4 = enable deepest rc6). For example, 3 would enable rc6 and deep rc6, and 7 would enable everything. default: -1 (use per-chip default) (int)
parm:           enable_fbc:Enable frame buffer compression for power savings (default: -1 (use per-chip default)) (int)
parm:           lvds_downclock:Use panel (LVDS/eDP) downclocking for power savings (default: false) (int)
parm:           lvds_channel_mode:Specify LVDS channel mode (0=probe BIOS [default], 1=single-channel, 2=dual-channel) (int)
parm:           lvds_use_ssc:Use Spread Spectrum Clock with panels [LVDS/eDP] (default: auto from VBT) (int)
parm:           vbt_sdvo_panel_type:Override/Ignore selection of SDVO panel mode in the VBT (-2=ignore, -1=auto [default], index in VBT BIOS table) (int)
parm:           reset:Attempt GPU resets (default: true) (bool)
parm:           enable_hangcheck:Periodically check GPU activity for detecting hangs. WARNING: Disabling this can cause system wide hangs. (default: true) (bool)
parm:           enable_ppgtt:Override PPGTT usage. (-1=auto [default], 0=disabled, 1=aliasing, 2=full) (int)
parm:           enable_psr:Enable PSR (default: false) (int)
parm:           preliminary_hw_support:Enable preliminary hardware support. (int)
parm:           disable_power_well:Disable the power well when possible (default: true) (int)
parm:           enable_ips:Enable IPS (default: true) (int)
parm:           fastboot:Try to skip unnecessary mode sets at boot time (default: false) (bool)
parm:           prefault_disable:Disable page prefaulting for pread/pwrite/reloc (default:false). For developers only. (bool)
parm:           invert_brightness:Invert backlight brightness (-1 force normal, 0 machine defaults, 1 force inversion), please report PCI device ID, subsystem vendor and subsystem device ID to dri-devel@lists.freedesktop.org, if your machine needs it. It will then be included in an upcoming module version. (int)
parm:           disable_display:Disable display (default: false) (bool)
parm:           disable_vtd_wa:Disable all VT-d workarounds (default: false) (bool)
parm:           enable_cmd_parser:Enable command parsing (1=enabled [default], 0=disabled) (int)
lumen
  • 505
Edit: I just found this post that MST seems to be working. https://askubuntu.com/a/552094/391692
  • People mentioned Dell's project Sputnik, which involved creating a version of Ubuntu for the XPS 13 9333 and the two prior models, and even selling a version with it by default. They are in the process of releasing a version for the new XPS 9343. In his post, Barton George says there are currently issues.
  • Once they complete these fixes, they will be sent upstream, and will land in future Linux kernels and versions. I have a 9333 and it works very well out of the box with any Linux distro that came out after Dell had pushed updates for the hardware.
  • Brand new laptops almost always have trouble with Linux. Windows drivers are all built and tested before the product is released. Linux drivers are built after, and take a while to make it to the mainline.
  • The flip side is that Intel's Ultrabook initiative has helped Linux compatibility greatly. Pretty much any mid-to-high end laptop you buy right now is a certified 'Ultrabook' and has the same chipset and graphics as the others of that generation. Things like wireless, camera, ACPI aren't the same between machines, but they typically come from a fairly small pool which tends to get support soon.
  • Try newer distros. Either a beta of Ubuntu 15.04 or Arch linux (among others) will have a newer kernel and more updated support for things in the Broadwell chipset.
Now... more to the point of your currently posted question. I haven't picked up a daisy chaining monitor or a MST hub to test out display port daisy chaining, and it seems like not many people care (many laptops have both HDMI and DP these days, the lack of dual output on the XPS 13 was almost a dealbreaker for me). But there is apparently progress. Check out the following from Phoronix: http://www.phoronix.com/scan.php?px=MTY4MDI&page=news_item
That was almost a year ago, so hopefully things are further along.
laydros
  • 66
