If you are hurrying to flag this question as a duplicate of this or this questions, please stop, the answers on those questions do not provide an answer to the question here.
After I asked this question I found that title and file name are pretty much different, so then I tried changing the pdf document's title to whatever I want to?.
I tried with Okular, but it doesn't let me change the title, I also tried GIMP but it just don't seem to have the option. I even tried verifying the document properties with Dolphin and it does not work either. How to change the title then?.
Hans
  • 1,301
Solution:
After a deep web search using Google, I found a tool called pdftk (Title in the manual: pdftk - A handy tool for manipulating PDF). To install the pdftk use the below line on the command line;
 sudo apt-get install pdftk
then created a file named updateTitle.txt containing the following information:
InfoKey: Title
InfoValue: New Title
And saved it in the same location the PDF is, then I ran in a terminal (in the PDF’s location):
pdftk input.pdf update_info updateTitle.txt output output.pdf
The PDF’s title is now "New Title".
kelalaka
  • 643
Hans
  • 1,301
