When upgrading from to the new Hardware Enablement Stack manually using this command:
sudo apt-get install --install-recommends linux-generic-lts-utopic xserver-xorg-lts-utopic libgl1-mesa-glx-lts-utopic libegl1-mesa-drivers-lts-utopic
This error comes up:
 indicator-bluetooth : Depends: unity-control-center but it is not going to be installed or
                                gnome-control-center but it is not going to be installed or
                                ubuntu-system-settings but it is not going to be installed
 libqt5feedback5 : Depends: libqt5multimedia5 (>= 5.0.2) but it is not going to be installed
 libqt5quick5 : Depends: libqt5gui5 (>= 5.2.0) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
What could be the cause and how can I solve this?
System:
Linux sandsturm 3.13.0-45-generic #74-Ubuntu SMP
  Tue Jan 13 19:36:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Zanna
  • 72,312
stego
  • 101
I had the exact same problem, and this worked for me:
  1. I installed the 14.04 (trusty) versions of those same packages first:
    sudo apt-get install --install-recommends linux-generic-lts-trusty xserver-xorg-lts-trusty libgl1-mesa-glx-lts-trusty libegl1-mesa-drivers-lts-trusty
  2. Once I installed those, I was able to run the command to upgrade the enablement stack:
  3. Lastly, a bit of cleanup:
    sudo apt-get autoremove
Edit:
After following the above steps, Steam tried to install a couple packages (libgl1-mesa-dri:i386 and libgl1-mesa-glx:i386) and they were failing. I was able to fix it easily:
sudo apt-get install libgl1-mesa-dri-lts-utopic:i386 libgl1-mesa-glx-lts-utopic:i386
I'll have to remember that pattern for packages in the future if they fail installing/upgrading (try adding -lts-utopic to the package name).
bmaupin
  • 5,371
