I am trying to install Ubuntu 14.04.1 (i386-32 bit) dual boot with Windows 7 (home premium 64 bit). I created a USB stick correctly, Checked for md5sum.
After manual option, I created swap, /, /home and proceeded. It gets stuck at detecting file systems.
I tried several times with following options:
  1. enabling wifi (which kept loosing and searching for connection)
  2. wired internet (worked fine (I hope) )
  3. with out internet (I.e without updates)
P.S. I just now un-installed opensuse 11.3 from dual boot with Windows. The memory which was freed from suse is in free space (Light Green) and not unallocated (black). is that a problem?
Alongside I am searching for windows help to convert the green space to black.
Screen shot of gparted from Try Ubuntu
Fabby
  • 35,017
If I were you, I'd:
  • Take a full system backup
  • Download and burn a DVD of 14.04.2 32 bit version as you seem to have a need for OpenOCD which doesn't seem to like 64-bit versions.
  • boot and follow these instructions,
  • at step 8 take "something else",
  • delete the 200GB /dev/sda6 partition and create a 32GB / and 128 GB /home in ext4 format.
  • leave the rest unallocated (to add to something when that one becomes full somewhere in the future)
Fabby
  • 35,017
I encountered the same problem as you when I tried to install Ubuntu 16.04 and Ubuntu 16.10. It was always stuck on Detecting file systems. I found out that the installation program will try to umount the path /isodevice, but the file is held by kernel, so umount fails.
At last, I opened the terminal and ran the command
sudo umount -l /isodevice
with success. Then I ran the installation program again. The problem did not occur again.
Zanna
  • 72,312
zhentao
If u stuck in detecting file ... ( cdrom failed ) Restart os , choose try ubuntu
  1. sudo umount -l /isodevice ( terminal )
  2. Reinstall ---> continue --> something else ( if u want to create manual partition )
  3. just using your " free space " ( if it equal 0 , change from your disk NTFS ( sub it )
  4. Finally , u will have free space create 3 partition ( swap , / , /home ) .
  5. Choose your region time and the rest
