I am trying to use apt-get to install a specific version of amsynth. If I simply do
sudo apt-get install amsynth
It installs version 1.3. However I would like to install version 1.4. After searching the archive, it seems 1.4 is available http://packages.ubuntu.com/search?searchon=sourcenames&keywords=amsynth.
I've allowed the universe packages (using the information in How do I enable the "Universe" repository?) and tried
sudo apt-get install amsynth=1.4.2-2
but the version cannot be found. How would I go about installing version 1.4?
Note: A potential solution is to install from https://launchpad.net/~nick-nickdowell/+archive/ubuntu/amsynth-master-daily.
However after running
sudo add-apt-repository ppa:nick-nickdowell/amsynth-master-daily
sudo apt-get update
sudo apt-get upgrade
I still only have version 1.3 installed. The only clue I have as to why this doesn't work is that when running update I get in the console
W: Failed to fetch http://ppa.launchpad.net/nick-nickdowell/amsynth-master-daily/ubuntu/dists/trust‌​y/main/binary-i386/Packages 404 Not Found
rwolst
  • 117
That will not work. You are using Ubuntu 12.04 or 14.04. How do you expect the system to know about the 1.4 version from a newer Ubuntu release?
If you want to install the newest version you could install from the personal archive https://launchpad.net/~nick-nickdowell/+archive/ubuntu/amsynth-master-daily Mind though: this will also probably uprade 1.3 to 1.4.
If you really want 1.3 and 1.4 together you need to install one of these from source so you can tell it to install in another directory.
You can pick "raring" as the latest release and version 1.4:
deb http://ppa.launchpad.net/nick-nickdowell/amsynth-master-daily/ubuntu raring main
deb-src http://ppa.launchpad.net/nick-nickdowell/amsynth-master-daily/ubuntu raring main
Signing key:
    1024R/062A9BBC (What is this?)
Fingerprint:
    D0BE1A6EB1A1DE103853721C1583CFE1062A9BBC
Rinzwind
  • 309,379
