68
I have a bunch of .html files in a directory. I want to look through each file and match a pattern (MD5). All of that is easy enough. The problem is I need to know what file the match was found in.
cat *.html | grep 75447A831E943724DD2DE9959E72EE31
Only returns the HTML page content where the match is found, but it doesn't tell me the file which it was found in. How can I get grep to show me the filename where my match is found?
BeMy Friend
  • 1,173
6 Answers6
82
grep -H 75447A831E943724DD2DE9959E72EE31 *.html
-H, --with-filename
              Print the file name for each match. This is
              the default when there is more than one file
              to search.
muru
  • 207,228
Cyrus
  • 5,789
35
I use this one all the time to look for files containing a string, RECURSIVELY in a directory (that means, traversing any sub sub sub folder) grep -Ril "yoursearchtermhere"
  • R is to search recursively (following symlinks)
  • i is to make it case insensitive
  • l is just to list the name of the files.
so answering your question grep -l '75447A831E943724DD2DE9959E72EE31' *.html will do but you can just do grep -Ril '75447A831E943724DD2DE9959E72EE31' to look for that string, case insensitive, in any file in any subfolder
muru
  • 207,228
thebugfinder
  • 2,331
11
You can try this
grep -rl '75447A831E943724DD2DE9959E72EE31' * > found.txt
Red Aura
  • 468
grep -r -H 75447A831E943724DD2DE9959E72EE31 *.html | awk -F : ' { print $1 } '
Alternative to
grep -r -l 75447A831E943724DD2DE9959E72EE31 *.html
Doing above will search recursively in the folder and subfolders and print the path of the file...
Zanna
  • 72,312
Drew
  • 51
I would do it like this:
find . -type f -name=*.html -exec grep -H 75447A831E943724DD2DE9959E72EE31 {} \;
Eliah Kagan
  • 119,640
azAttis
The answer posted by Cyrus is absolutely proper and is The Right WayTM to do it with grep if we only need to find files. When filenames need to additional parsing or operations on the matched filenames, we can resort to using while loop with if statement. Here's an example where list of filenames comes from very commonly used find+while structure for safe parsing of filenames.
find -type f -name "*.html" -print0 | while IFS= read -r -d '' filename
do
    if grep -q 'PATTERN' "$filename"
    then
        printf "%s found in %s\n" 'PATTERN' "$filename"
        # Here we can insert another command or function
        # to perform other operations on the filename
    fi
done
