According to your comment the “haystack” of your search is a set of gzipped text files (based on the file name extension .gz). You can scan them with the zgrep command, a wrapper around the grep command that decompresses gzipped files on the fly and supports most of the same options as grep itself.
Thus you can simply run
zgrep -oHe 7505857289 <FILES>...
which will print the name of the source file followed by a colon and the matching character sequence for each match.
If you need a specific output format I recommend that you transform it. For matching text followed by a space and the source file name that would be:
zgrep ... | sed -re 's/^([^:]*):(.*)$/\2 \1/'
