I am kinda desperate and any help will be appreciated. I am running Ubuntu 14.04 on a Lenovo T530i, and my HDD was almost full.
I planned to buy an external HDD this week end and transfer some data, but then as I was working I got a notification from VMWare that the host OS had 3 gb free only and that it will shutdown, so I switched off my VMWare player and to find out that my whole computer has been wiped out, can't find a single data anywhere.
Is there a way to retrieve my data as this is really a big loss for me.
Regards,
lsblk command:
davwise@davwise-ThinkPad-T530:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 465,8G 0 disk
├─sda1 8:1 0 243M 0 part /boot
├─sda2 8:2 0 1K 0 part
└─sda5 8:5 0 465,5G 0 part
├─ubuntu--vg-root (dm-0) 252:0 0 457,8G 0 lvm /
└─ubuntu--vg-swap_1 (dm-1) 252:1 0 7,7G 0 lvm [SWAP]
sr0 11:0 1 1024M 0 rom
mount command:
davwise@davwise-ThinkPad-T530:~$ mount
/dev/mapper/ubuntu--vg-root on / type ext4 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
none on /run/user type tmpfs (rw,noexec,nosuid,nodev,size=104857600,mode=0755)
none on /sys/fs/pstore type pstore (rw)
/dev/sda1 on /boot type ext2 (rw)
rpc_pipefs on /run/rpc_pipefs type rpc_pipefs (rw)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
vmware-vmblock on /run/vmblock-fuse type fuse.vmware-vmblock (rw,nosuid,nodev,default_permissions,allow_other)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=davwise)
cat /etc/fstab command:
davwise@davwise-ThinkPad-T530:~$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# /dev/mapper/ubuntu--vg-root / ext4 errors=remount-ro 0 1
# /boot was on /dev/sda1 during installation
# UUID=3be6bedc-7d14-458b-b075-7845025e4e4a /boot ext2 defaults 0 2
# /dev/mapper/ubuntu--vg-swap_1 none swap sw 0 0
Edit: Result of testdisk
