I have encountered the "bootmgr is missing" error with my Windows 7 computer and I was not able to boot to Windows beforehand either. I am currently attempting to recover my files before I reformat the Windows OS on my C: drive. That said, I am booting from a USB using Ubuntu and am in the "trial" version (just trying it without installing it).
I do not see my hard drive or the drive that would presumably be my C: drive in Windows when I look through the devices. I am not sure where my files may be but I am fairly certain they have not been deleted or formatted over.
I am strictly looking for ways to recover the files to an external drive and not so much how to dual boot or permanently install Ubuntu.
LiveWireBT
  • 29,597
Assigning letters to drives is the traditional way of addressing hard drives and partitions in the user interface for DOS, Windows and related operating systems. Other operating systems have different naming schemes:
Usually, Ubuntu running in a live session environment is capable of mounting Microsoft filesystems like FAT and NTFS. The filesystems should be available for mounting in the filemanager or be automatically mounted already. It should be easy to find the right filesystem when they were labeled accordingly, otherwise you have to guess by size, remember the position of the partition in a partition manager or dumb trial an error. Typically external filesystems are mounted below /media.
In some cases you may no be able to mount a certain filesystem:
LiveWireBT
  • 29,597
Your "C" drive will be located /media/<possibly_a_long_series_of numbers>
Use your file manager (Nautilus), go up(down) to root (/) and then into /media, and you will see it.
It is possible there might be ownership/permission problems in manipulating the files within this directory, or transferring them to an external, but just open it/them as root.
Nodak
  • 690
