I tried Every solution on AsKuBunTu. The reason why I am asking the question is : No answer solved my issue.
I started Ubuntu which causes eye strain(same time spent on Win-7 never caused eye strain).
As per answer topped on google search like Here, Here and many more places but no answer worked.
As per Experts here , they said following should work xrandr -s 1366x768 -r 75 , but it gives me message Rate 75.0 Hz not available for this size .
Also some Expert also gave answer like This which obviously not working .He says use Compiz using sudo apt-get install compizconfig-settings-manager . It sets the refresh rate , but after I reboot , all is gone and set to 60Hz , I dont know was that refresh rate in Compiz just for our satisfaction or what ?
And now please answer genuinely , dont answer like use Redshift , flux , as it Does Not solve the issue , I dont like my screen in Red color.
My Os: Ubuntu 14.04 Trusty Tahar.
Please answer if you know , I really dont want my eyes dried , tired , stressed anymore on Ubuntu.
Pratik Joshi
  • 203
You did not read the links I gave you nor did you post sufficient information for me to answer.
I can take a guess.
You have to manually add a mod line and you will have to modify this answer to match your hardware / xrandr output.
Run cvt
cvt 1366 768 75.0
notice how the desired refresh rate is added to your resolution ;)
output will look like this:
# 1368x768 74.90 Hz (CVT) hsync: 60.30 kHz; pclk: 109.50 MHz
Modeline "1368x768_75.00"  109.50  1368 1448 1592 1816  768 771 781 805 -hsync +vsync
Add it to xrandr (without the "Modline" part)
xrandr --newmode "1368x768_75.00"  109.50  1368 1448 1592 1816  768 771 781 805 -hsync +vsync
Now here is where you did not post sufficient information, so I can not write an answer.
The output of xrandr shows your display name, mine shows
eDP connected 1366x768+0+0
so mine is eDP. Yours may be VGA-0 or LVDS or ....
run xrandr with your display name
xrandr --addmode eDP 1366x768_75.00
NOW run xranrd to set your desired resolution
    xrandr --output eDP --mode 1366x768_75.00
If you have a problem post the output of xrandr and the commands I gave you exactly as you enter them and any error messages.
Don't forget to ask nice because I am a volunteer.
Panther
  • 104,528
