I have a 4GB pendrive. I have installed ubuntu 14.04 into it. But, ubuntu is not booting from it. Whenever I try to boot from it, only a black screen is up. May be the bootloader is keep on searching for a valid boot source within my pendrive which does not exist at all. Please help me resolve this problem.
I followed these steps to install ubuntu into my pendrive:
  • I created an extended-partition covering all the 4GB.
  • I created two primary partitions within it.
    • partition one - ext4 filesystem - 3.5 GB
    • partition two - ext2 filesystem - rest of the total memory
  • I used a liveUSB to install ubuntu into my pendrive
  • I chose my partition one - ext4 fs for ubuntu installation with the mount point as /
  • I chose my partition two - ext2 fs as a swap area for the ubuntu to be installed
  • I then hit Install Now which did the installation, similar to an installation in HDD
Have I done anything wrong? Do I need to do more things? Help me use ubuntu from my pendrive. Thanks in advance.
Update: I tried for solutions here and here. Nothing helped. They were just stuffs related to liveUSB creation which is not my case.
Ramvignesh
  • 1,862
  • 20
  • 31
The 4GB USB drive is too small for a full install of Ubuntu 14.04
The installer should have refused to install Ubuntu in a 3.5 GB partition. A full install requires about 5GB / partition. So you will need at least an 8 GB USB drive. I recommend a 16 or 32 GB drive if you intend to install many programs and store large personal files.
One thing to remember when you install Ubuntu on an USB drive, from a Live USB is to make sure you choose the correct destination drive for installation as well as the bootloader location.
Your drives are denoted by /dev/sda, /dev/sdb, /dev/sdc etc. Say /dev/sdc is the correct USB drive (check by size). Then during install make sure you choose /dev/sdc for bootloader location. Don't choose partitions inside such as /dev/sdc1. Choosing the whole drive (rather than a partition in it) will install the bootloader in the MBR of that USB drive.
There are other ways of doing a full install in an USB, such as using a virtual machine. See How do I install Ubuntu to a USB key? (without using Startup Disk Creator) for more details.
Hope this helps
user68186
  • 37,461
