Ok, I know that this has been asked a thousand times, but I've spent the last 5 hours trying to setup my Toshiba Satellite to dual boot 14.04 and Win8.1 and I'm at the point where throwing the laptop off the window to test it's anti-gravity capabilities sounds like a pretty good idea.
So, to cut a long story short: Followed this guide: Installing Ubuntu Alongside a Pre-Installed Windows with UEFI Fastboot is disabled. UEFI is enabled. LiveCD works as it should. Installation is complete. After restart laptop boots immediately to PC. Boot-repair returns this http://paste.ubuntu.com/10147575/ . I am nostalgic of the times before EFI. Ah the times we had, when a linux installation would take less than 45 minutes. Anyway, if anyone could offer any advice, I would owe them a great debt (not to mention my sanity)
GeMar
  1. Boot Live CD / Live USB, select try Ubuntu
  2. Once it's loaded, open terminal CtrlAltT
  3. Do the following
sudo mount /dev/sda8 /mnt
sudo mount --bind /dev /mnt/dev
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys /mnt/sys
sudo chroot /mnt
NOTE: the /dev/sda8 is your Ubuntu partition, from what I see in your pastebin file. Double check that with lsblk command, and see if you recognize that partition, and it has the right size
  1. Do update-grub and then sudo grub-install /dev/sda
  2. Reboot
Try this, see what happens. Basically what we're doing here is installing grub on the boot sector of the hard drive, not just one partition /dev/sda8.
Ravexina
  • 57,256
When you boot up hold the SHIFT key. If Ubuntu installed correctly, GRUB should load and give you options for which OS you want to start. Try and post results.
Ravexina
  • 57,256
