I looked at several related questions because some questions remained for me.
I have just bought a Asus Ultrabook with Windows 8 pre-installed, 500gb HDD and 24gb SSD. Apparently (according to some other answers to related questions) Windows is installed in the 24gb SSD because it boots very fast. I intend to follow this tutorial http://www.everydaylinuxuser.com/2014/05/install-ubuntu-1404-alongside-windows.html but I have few questions about the outcome and process.
First, Can I install only Ubuntu in the SSD (considering I'm novice and didn't find any specific tutorial) and keep windows in the HDD, does worth doing that ? I intend to use MatLab, Python (I'm still novice at Python too, so nothing demanding), Mathematica and others, in Windows I need to use AutoCad 2d and some other similar programs. If I do install Ubuntu in SSD, would it be "painful" to access bios as it is with Windows ? (I can't access directly pressing F2, I need to follow some steps and then restart twice the computer.) Then, assuming everything above is ok, does that tutorial works for my case ? He shrinks partitions on Windows, could it result in a problem since "Windows is installed in the SSD"?
Obs: I'm assuming that SSD couldn't have Windows and Ubuntu since it is too small.
Don't do it!
Leave the SSD alone and install on the HDD. Then use bcache to use the 24GB HDD as a cache for the HDD just like Windows uses SRT!
Follow this advice: Installing Ubuntu Alongside a Pre-Installed Windows with UEFI instead.
Fabby
  • 35,017
You can install Ubuntu on the small SSD. I did that, but that small SSD isn't very reliable. It is already going bad for me, it has many bad sectors. I wouldn't recommend it honestly.
Pants
  • 141
