First of all, I have looked at a bunch of threads that are similar, but none of the solutions work for me. I am trying to install nvidia drivers (nvidia-340, specifically) but when I reboot the system always hangs after showing the purple splash screen. I can also hear the login drum sound, but I just see black. Up until now, the only solution has been to uninstall the driver and boot in again.
I have tried
  • Changing /etc/default/grub to change the resolution on startup, among other items in this file
  • trying different versions of the driver, including the proprietary one direct from nvidia
I have an ASUS N751JK and am dual booting with Windows, should that make any difference.
Any other ideas about what I can try? Thanks in advance.
skaz
  • 1,353
There is a complicated answer here that worked for me: https://bugs.launchpad.net/ubuntu/+source/nvidia-graphics-drivers-331/+bug/1362848
I fixed the problem with my nvidia graphic card using the post #15.
Thank you very much kcpr (mkasprzyk5) without your help I would not be albe to fix it.
Here how I fixed in details:
Log out and go to the console:
CTRL-ALT-F1
If (like me) you tried to install latest nvidia driver (nvidia-340 ...), you need to revert back with following commands:
sudo apt-get install ppa-purge
sudo ppa-purge xorg-edgers
sudo apt-get purge nvidia*
Then copy all xorg config files in a temporary dir:
cd
mkdir temp
sudo mv /etc/X11/xorg.conf* ./temp/
Then clean, update, upgrade and reboot the system:
sudo apt-get autoremove
sudo apt-get update
sudo apt-get upgrade
sudo reboot
Go to the console:
CTRL-ALT-F1
Install nvidia 331:
sudo apt-get install nvidia-331 nvidia-prime
Copy the old xorg.conf made by nvidia back in its directory:
sudo cp temp/xorg.conf.nvidia-xconfig-original /etc/X11/xorg.conf
And edit it (I used vi, you may prefer nano):
sudo vi /etc/X11/xorg.conf
To be as the following:
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "intel"
EndSection
Section "Device"
    Identifier "intel"
    Driver "intel"
    BusID "PCI:0@0:2:0"
    Option "AccelMethod" "SNA"
EndSection
Section "Screen"
    Identifier "intel"
    Device "intel"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:1@0:0:0"
    Option "ConstrainCursor" "off"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
    Option "AllowEmptyInitialConfiguration" "on"
    Option "IgnoreDisplayDevices" "CRT"
EndSection
Eventually reboot the system:
sudo reboot
Now I have nvidia set as graphic card and the hardware acceleration works fine.
skaz
  • 1,353
Not sure about 14.04, but on 22.04 LTS I recommend installing NVIDIA drivers via the "Additional Drivers" GUI.
Note: beware of kernel upgrades.
I recommend the GA kernel.
Langdon
  • 81
