How to remove ubuntu 14.04 dual boot with windows 7 ?
Ashu_FalcoN
  • 2,118
  1. Turn on the computer.
  2. Wait for the HP logo to show.
  3. Keep tapping the Shift key until you see this screen:
Grub with Windows
  1. Use the and keys on your keyboard (no mouse!) to navigate to Windows and you should be back up and running!
If your screen does not contain an entry for Windows, we're sorry to say but after 2 months, all your files will be lost. The only thing you can do is take the Windows Recovery Environment from the same menu which will wipe your entire PC. If you also have no recovery environment in the menu, please restore your PC with the HP Recovery DVD and then your file back-up.
If you also have no HP Recovery DVD, contact HP, they will be able to send you one (this is probably a payable service)
Alternatively
You can use this procedure to reset the Ubuntu password, which would give you access to Ubuntu itself.
Fabby
  • 35,017
I have an HP G62 and I've reinstalled Windows 7 once. I made backup DVDs.....they didn't work. I downloaded Win 7 from Microsoft. I don't know the exact location but try this : http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/where-can-i-download-windows-7-iso-i-have-a/7d964b05-2be9-4800-bc7f-3ca30356fc3d or try searching on the Microsoft site for Windows 7 download. They usually call it a "Digital River" server.
So I burned it to a DVD and installed it fine, and validated it using the number on the license key sticker on the back of the PC. The advantage is that you don't get all the crapware installed that came with your PC. No trialware, etc. It runs fine.
Since then I've learned to use Linux Mint and haven't used Windows in maybe a year. I sure hope you give Ubuntu a try, because it's a better operating system and much safer.
-1
Ouch, that sucks.
There are a few ways to do this, the "best" (almost certainly will work):
Boot your computer
Press Esc
What do you see? If you see an option that says "Windows" or "Windows 7" or something like that, use the down arrow to move so that that choice is highlighted.
If the above doesn't work, you may need to boot into your BIOS setup program. Instead of pressing Esc, you may need to press one of the function keys (I think yours may be f10 based on the model).
IronManMark20
  • 269
