I know it is relatively easy creating a custom keyboard layout, but it seems like I have to do that for both two desktop environments installed on my Ubuntu 14.04 laptop (Unity and KDE). And what is more important - I already have a .klc (microsoft keyboard layer creator) file with desired layout done in windows. Is there some tool that offers importing keyboard layout out from windows available for linux and especially for Ubuntu?
UPDATE:
@Helio, just realized that .klc is not binary but a text file, so I do now include its contents:
KBD Glagolic    "Glagolotsa BG phonetic - new"
COPYRIGHT "(c) 2012 Company"
COMPANY "mycomp"
LOCALENAME "bg-BG"
LOCALEID "00000402"
VERSION 1.0
SHIFTSTATE
0 //Column 4 1 //Column 5 : Shft 2 //Column 6 : Ctrl
LAYOUT ;an extra '@' at the end is a dead key
//SC VK_ Cap 0 1 2 //-- ---- ---- ---- ---- ----
1e A 0 e0d6 -1 -1 // Private Use , <none>, <none> 1f S 0 e192 -1 -1 // Private Use , <none>, <none> 20 D 0 e133 -1 -1 // Private Use , <none>, <none> 21 F 0 e0f1 -1 -1 // Private Use , <none>, <none> 22 G 0 e037 -1 -1 // Private Use , <none>, <none> 23 H 0 e073 -1 -1 // Private Use , <none>, <none> 24 J 0 e1c4 -1 -1 // Private Use , <none>, <none> 25 K 0 e0f9 -1 -1 // Private Use , <none>, <none> 26 L 0 e130 -1 -1 // Private Use , <none>, <none> 2c Z 0 e1c0 -1 -1 // Private Use , <none>, <none> 2d X 0 e167 -1 -1 // Private Use , <none>, <none> 2e C 0 e00e -1 -1 // Private Use , <none>, <none> 2f V 0 e147 -1 -1 // Private Use , <none>, <none> 30 B 0 e102 -1 -1 // Private Use , <none>, <none> 31 N 0 e04b -1 -1 // Private Use , <none>, <none> 32 M 0 e002 -1 -1 // Private Use , <none>, <none> 39 SPACE 0 0020 0020 -1 // SPACE, SPACE, <none> 53 DECIMAL 0 002e 002e -1 // FULL STOP, FULL STOP,
KEYNAME
01 Esc 0e Backspace 0f Tab 1c Enter 1d Ctrl 2a Shift 36 "Right Shift" 37 "Num *" 38 Alt 39 Space 3a "Caps Lock" 3b F1 3c F2 3d F3 3e F4 3f F5 40 F6 41 F7 42 F8 43 F9 44 F10 45 Pause 46 "Scroll Lock" 47 "Num 7" 48 "Num 8" 49 "Num 9" 4a "Num -" 4b "Num 4" 4c "Num 5" 4d "Num 6" 4e "Num +" 4f "Num 1" 50 "Num 2" 51 "Num 3" 52 "Num 0" 53 "Num Del" 54 "Sys Req" 57 F11 58 F12 7c F13 7d F14 7e F15 7f F16 80 F17 81 F18 82 F19 83 F20 84 F21 85 F22 86 F23 87 F24
KEYNAME_EXT
1c "Num Enter" 1d "Right Ctrl" 35 "Num /" 37 "Prnt Scrn" 38 "Right Alt" 45 "Num Lock" 46 Break 47 Home 48 Up 49 "Page Up" 4b Left 4d Right 4f End 50 Down 51 "Page Down" 52 Insert 53 Delete 54 <00> 56 Help 5b "Left Windows" 5c "Right Windows" 5d Application
DESCRIPTIONS
0409 Glagolotsa BG phonetic - new LANGUAGENAMES
0409 Bulgarian (Bulgaria) ENDKBD
This example (halfly) implements glagolitic alphabet as custom keyboard layout.
lrd
  • 151
The answer is no.
Mind though that a topic related to this already exists on AskUbuntu: Create my own keyboard input layout and it has not got an answer on how to import a .klc. It only states alternatives.
And our own help on creating a new keyboard lay-out also does not mention any import tool.
The best way to create a new lay-out is by copying an existing one from Ubuntu to a new name and then edit the changes into this new lay-out. So it is all manual work.
Rinzwind
  • 309,379
