15
At first this issue seemed to be related solely to usb's. When I insert a USB i get "Unable to mount xGb volume Not Authorized to perform operation"
Previously it would prompt for root password to mount. Upon closer examination this appears to be related to the privilege escalation prompt. Any feature that would normally require a root password doesn't prompt therefore is denied.
As another example under System Settings > User Accounts I can't click the unlock button. Previously it would prompt for root, now I no longer even have the option.
Edit: I know how Sudo works, but why isn't this happening through the GUI? Previously if you plugged in a flash drive it'd prompt for PW then mount automagically. It seems to be an issue with GUI privilege escalation in general not just mounting drives. Even if I go to Disks and click mount it doesn't mount because it never prompts for PW.
EHM
  • 161
9 Answers9
52
In Ubuntu 18, this error is caused by Chrome Remote Desktop. The solution is:
  1. Stop the Chrome Remote Desktop Service:
    /opt/google/chrome-remote-desktop/chrome-remote-desktop --stop
  2. Open all external disks, that logo appears
  3. Start again the Chrome remote desktop service:
    /opt/google/chrome-remote-desktop/chrome-remote-desktop --start
I think you have to do this after each reboot.
Jason Liu
  • 117
You have already opened some application which is holding the mount for lock so you are not able to mount it. The application might be gparted,ubuntu-installer or others.
I recently has this issue as a result of having installed Chrome Remote Desktop. Other commenters have suggested uninstalling it however I use it often and have trouble using other remote tools due to being on a university network. At any rate, killing all the processes which referred to chrome-remote-desktop worked for me.
For me the missing bit was the user not being member of the group plugdev
Terminal way to add myuser to the group:
sudo usermod -aG plugdev myuser
After this I didn't even have to logout or restart any services.
rosch
  • 8,168
As a quikly workaround, if you open RemoteDesktop, and stop your computer to be accesible from Remote Acces section (click on the trash icon) then you recover the elevated privileges function. When you activate it again, the drive remains mounted but the elevation procces fails again
I was facing an issue with reading the hard disk drives.
The disk was actually /dev/sda8. I had to create a mount point.
sudo cd mkdir /media/mydisk
sudo mount /dev/sda8 /media/mydisk
And this worked for me.
To verify it, use
cd /media/mydisk
ls
For me the most elegant solution was to remove my computer from https://remotedesktop.google.com/access due to the fact I was not using the remote access and left a dangling node and it looks like Linux was just trying to protect the system with "Not Authorized to perform operation" of new devices? Anyhow this worked for me.
I posted my fix in another question before I saw this one:
sudo apt-get install --reinstall gnome-session
Please be cautious this might break some other packages. In which case try to reinstall the package.
rodney
# place in
#create dir if needed
#/etc/polkit-1/localauthority/50-local.d/automount.pkla
[Allow Automount]
Identity=unix-group:plugdev
Action=org.freedesktop.udisks2.filesystem-mount*
ResultAny=yes
ResultInactive=yes
ResultActive=yes
[Allow Eject]
Action=org.freedesktop.udisks2.eject-media*
ResultAny=yes
ResultInactive=yes
ResultActive=yes
[Allow Mounting of fstab]
Action=org.freedesktop.udisks2.filesystem-fstab*
ResultAny=yes
ResultInactive=yes
ResultActive=yes
