My situation is as follows. I upgraded my ubuntu version (12.04 to 14.04), using as a fresh install ~ it consistently failed when using update manager or apt-get.
I kept my home on a separate partition, I have backups of the important information.
when I set up 12.04 I used an encrypted home drive.
After my upgrade, my encrypted home is not mounting correctly and I'm currently unable to decrypt it.
I also have the following folders / files on the partition:
    └── davem ~ this my old home drive, it contains the files .ecryptfs .Private
README.txt and Acces-your_Private-Data.desktop
    └── .ecryptfs ~ this again contains a 'copy' of my davem folder, here follows a copy
of the tree, from this directory.
    └── davem
        ├── .ecryptfs
        │   ├── auto-mount
        │   ├── auto-umount
        │   ├── Private.mnt
        │   ├── Private.sig
        │   └── wrapped-passphrase
        └── .Private
            ├── ECRYPTFS_ ... and many other 'files' which I guess correspond to my original directories and files.
when using cryptkeeper I select the 'import EncFS folder', however in the window that opens I do not see the hidden .ecryptfs folder, and if I type it in manual (or any of it's sub folders) I get the response that the folder is not am EncFS encrypted folder.
So I have The questions regarding this sitation:
1) how to determine the type of encryption on the folder. 2) how to mount it so as I can access the data on it.
I assume that the password was my login password on my system, so I know what it is.
any assistance it greately appreciated.
If the mods feel that this should belong on the 'linux / unix' stack overflow, feel free to move it over.
Thanks all.
David.
DaveM
  • 143
Looks like it's using eCryptfs encryption.
If the home folders are set up for the same locations, and you're using the same username and same passphrase, I think you should be able to log in & decrypt your home as usual... unless there were major changes from 12.04 to 14.04, I'm not sure.
You could mount it with ecryptfs-recover-private if you just want to read & copy the files over to a new (encrypted) profile.
Or you could try ecryptfs-rewrap-passphrase to "unwrap an eCryptfs wrapped passphrase, rewrap it with a new passphrase, and write it back to file" using your old & new login passphrases. Then you should be able to decrypt & use your old home folder again (if it's in the right location, etc).
See the man pages for more info, and keep/make a backup of the files before changing them, just in case. Really should have a backup of the un-encrypted files too (encrypted using a different method perhaps, like a tar.gz.gpg) to be extra careful too.
Xen2050
  • 8,943
