I am using following article to fix this issue: http://ubuntuforums.org/showthread.php?t=2246183
This is the output I get:
aditya@aditya-Vostro-3446:~/$ sudo apt-get purge wine
[sudo] password for aditya:
Reading package lists... Done
Building dependency tree
Package wine is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 41 not upgraded.
aditya@aditya-Vostro-3446:~/$ sudo apt-get autoremove
aditya@aditya-Vostro-3446:~/$ sudo apt-get install wine
 wine : Depends: wine1.6 but it is not going to be installed or
                 wine1.7 but it is not going to be installed
And when I try to install wine using ubuntu software center I get following message:
q4wine: Depends: libc6 (>= 2.14) but 2.15-0ubuntu10.9 is to be installed
        Depends: libgcc1 (>= 1:4.1.1) but 1:4.6.3-1ubuntu5 is to be installed
        Depends: libqt4-dbus (>= 4:4.5.3) but 4:4.8.1-0ubuntu4.8 is to be installed
        Depends: libqt4-network (>= 4:4.5.3) but 4:4.8.1-0ubuntu4.8 is to be installed
        Depends: libqt4-sql (>= 4:4.5.3) but 4:4.8.1-0ubuntu4.8 is to be installed
        Depends: libqt4-xml (>= 4:4.5.3) but 4:4.8.1-0ubuntu4.8 is to be installed
        Depends: libqtcore4 (>= 4:4.8.0) but 4:4.8.1-0ubuntu4.8 is to be installed
        Depends: libqtgui4 (>= 4:4.5.3) but 4:4.8.1-0ubuntu4.8 is to be installed
        Depends: libstdc++6 (>= 4.1.1) but 4.6.3-1ubuntu5 is to be installed
whizcreed
  • 133
You can try one of the following:
sudo apt-get -f install
To force install the dependencies and such.
Or try installing it via the Ubuntu Wine Team PPA:
sudo add-apt-repository ppa:ubuntu-wine/ppa
sudo apt-get update
sudo apt-get install wine1.7
blade19899
  • 26,994
Try to install directly the last version:
or (previous version):
sudo apt-get install wine1.6
-1
you need to reinstall package ttf-mscorefonts-installer because by default the license for this package is not accepted, you need to manually accept the license for this package."Microsoft's core fonts package has unmet dependencies in wine.
"first remove them from your system as
sudo apt-get remove ttf-mscorefonts-installer
then re-install
sudo apt-get install ttf-mscorefonts-installer
then accept the license using tab key in a graphical interface after doing this install any version of wine,you can install wine from software centre .This package is also required if you want to install adobe flash player plugin.Note: wine1.6.2 is the stable release and Wine 1.7.34 is the latest wine release as of now.You can refer to
wine HQ
Mudit Kapil
  • 2,081
