SYSTEM SPECS:
Macbook Pro (64 bit), Ubuntu 14.04,
kernel version: 3.13,
graphics drivers: nvidia-331
Recently I've been experiencing wi-fi problems on a regular basis in 14.04 with kernel version 3.13, and I was getting really annoyed. I did a bit of research and found a bug report on launchpad- the submitter reported that upgrading from the 3.13 kernel to 3.18 had solved his problem entirely, so I decided to try it out.
To upgrade my kernel I followed the instructions in the linked thread- I navigated to the ubuntu kernel webpage (hopefully the right one) , dowloaded linux-headers-3.18.0-031800-generic_3.18.0-031800.201412071935_amd64.deb, opened the file with Software Center, and hit "install."
I didn't get any errors during the actual install process. However, when I rebooted my system I noticed that the errors/log output was different when the system was booting up (before it would always say "registered C22fgy.phy" or something similar- I dont remember). Now, however, the following errors show up.
[ 0.026781] [Firmware Bug]: ioapic 2 has no mapping iommu, interrupt remapping will be disabled
[ 1.219547] pci 0000:00:01.0: ASPM Could not configure common clock
[ 2.629436] i8042: No controller found
The system booted to the login screen fine (Unity seemed to be working OK, with the widget bar functioning in the top of the screen). However as soon as I tried to login, I get a "system problem detected" window, and Unity doesnt load- my wallpaper shows up, but there's no desktop environment to accompany it (even the widgets in the top corner disappeared). On top of that, wifi doesnt seem to be working at all under 3.18 (havent tried wired yet). I can still get into the shell via cntrl+alt+f1+fn (I'm on a laptop), but I'm not really sure what I'd use it for. Running uname -r verifies that the 3.18 kernel has actually been installed.
I can, using grub, still boot normally using the 3.13 kernel (that's actually what I'm typing this from).
I was hoping you guys could help me out with (correctly) installing the 3.18 kernel, as well as with resolving the problems that are popping up for me. If you guys need any more information, I'd be happy to provide it.
Thanks!
