I installed an "upstream kernel" (downloaded deb and installed with dpkg) because of an issue I have with the default kernel (see https://bugs.launchpad.net/ubuntu/+source/linux/+bug/956918) Now the custom battery settings I had are lost. I used the kernel modukle tp-smapi to change this settings on a thinkpad. If I try to load this module now, it fails because it was not built for this kernel. The installed packages are "tp-smapi-dkms" and "tp-smapi-source". Automatic rebuilding seems not to have been triggered. How can I do it manually?
didi_X8
  • 241
Besides installing the linux-image-... package, you also need linux-headers-... . After installation of the headers, the modules for that kernel should be build automatically. If not, manually trigger a installation of modules for the current loaded kernel:
sudo dkms autoinstall -k $(uname -r)
Lekensteyn
  • 178,446
