This is the question I already have an answer, but answering for others. I have been having a problem, whenever I try to shutdown, suspend or restart Ubuntu or Gnome 3, the shut-down screen just freezes, and it didn't shut down.
The question is how to find a cause and how to fix?
Aleks
  • 412
  • 15
The answer for this one was: After I have clicked on a button shutdown and the log-out screen has shown, I pressed the esc key and I could see the error text messages, and I have found the message:
Waiting for Redis to shutdown ...
After finding out what script is used to shutdown Redis, I have found out it is:
/etc/init.d/redis_6379
When I tried manually to shutdown manually from console running a command:
sudo /etc/init.d/redis_6379 stop
I got the same error message. I was one step closer to the solution. Even though maybe the solution was not as perfect as it could be, but I managed to solve my problem. I have edited the file:
sudo gedit /etc/init.d/redis_6379
And found the:
echo "Waiting for Redis to shutdown ..."
Edited the surrounding code (commented out some lines and added one other command to shutdown the Redis server)
/etc/init.d/redis-server stop
#while [ -x /proc/${PID} ]
#do
  #sleep 1
#done
And whola! The Ubuntu now will not stuck in an infinite loop, and now I could shutdown, suspend and restart again! :)
Aleks
  • 412
  • 15
