I'm planning to install Ubuntu Desktop 14.04 alongside an existing Windows 8.1 installation (following the guide on Installing Ubuntu Alongside a Pre-Installed Windows with UEFI).
I've partitioned my hard disk as follows at the moment:
  • 1000MB healthy recovery partition
  • 260MB healthy EFI system partition
  • 1000MB healthy OEM partition
  • ~427GB NTFS healthy (boot, page file, crash dump, primary) (Windows 8.1; C:)
  • ~16GB unallocated
  • 450MB healthy recovery partition
  • ~439GB NTFS healthy primary partition (B:)
  • 25GB NTFS healthy primary partition, don't want to touch it, it's the Lenovo partition (D:)
  • 20GB healthy recovery partition
I probably can shrink the C-disk at the end and make a new partition of at least around 40GB.
If possible, it would be my preference to create a new partition there and install Ubuntu on that one. That way, I keep about half the disk for the B-disk, without any installation, so I can use it for backups.
However, I'm not sure if 40GB will be enough if I would install a lot of additional software (would it?). There will not be any data there as I will put it all on B:. Would it be possible to have the ubuntu base installation in one partition and all additional software on another one?
If that's possible, I assume that 16GB is more than enough for the base installation. Is this correct? Then I don't have to shrink the C-disk. In the guide I linked earlier, they say at least 8GB, but better 20GB.
I have yet to get over 10Gb for all software I installed and that includes Apache and MySQL (with the database on a 2nd partition). Excluding my personal data since I keep that on another disk.
Yes, if you install software from source you can choose where it needs to install. But ... I would not bother. It is a lot of hassle and not worth the time.
20Gb is included /home/. It is pretty easy to keep /home/ under 2.5Gb by moving all the directories to another partition and use that to store your personal data with a symlink to /home/.
Rinzwind
  • 309,379
