I want to install xubuntu-desktop (a very large metapackage) but leaving out some of the packages on it (around 10). The current way I do this is in two steps: 1) install metapackage, and 2) purge unwanted packages. I wonder whether there is a more efficient and clean method to do this.
I thought apt-get would accept an instruction like install this except these but very surprisingly it seem not.
A potential solution would be to run the command sudo apt-get install xubuntu-desktop, then select No, and copy all the packages listed in the terminal, manually deleting the undesired ones. However this could be even more time consuming than the two-step procedure mentioned earlier, also risking to end up with bad dependencies.
Any ideas on how to make this in one simple command-line instruction?
You could script the task. I'm pretty sure I posted this elsewhere, but can't find it now. First, create a file with the packages you don't want. For example:
$ cat dont-want.txt
memtest86+
wireless-tools
firefox
evince
Then parse the output of apt-cache depends:
apt-cache depends xubuntu-desktop | awk '$1 == "Depends:" {print $2}' | grep -vFf dont-want.txt
This should include the packages on which the metapackage directly depends, without the packages you excluded. Then you can use xargs to install:
  grep -vFf dont-want.txt |
  sudo xargs apt-get install
If the unwanted package is not a direct dependency, you would need to use apt-rdepends instead of apt-cache depends.
You can also use Apt Pinning to enforce the ban: How to forbid a specific package to be installed?
muru
  • 207,228
