I am using Ubuntu 10.04. And I want to upgraded my php version. When i am upgrading my PHP version(5.3.2 to 5.3.6) but After every updation Its show PHP version 5.3.2..
Edit:: I have checked "Ubuntu repository", PHP 5.3.6 is not avalable. :(
6 Answers6
First add the following lines to the /etc/apt/sources.list.d/php5-ppa.list file using your favourite editor.
deb http://ppa.launchpad.net/nginx/php5/ubuntu maverick main
deb-src http://ppa.launchpad.net/nginx/php5/ubuntu maverick main
Then run the following command to add a key for the newly added repositories:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 00A6F0A3C300EE8C
After that you can update Ubuntu's software and upgrade PHP:
aptitude update
aptitude full-upgrade
cedric.walter
  • 270
I would recommend using my (Ondrej's) PPA, the answer taken from another Q&A thread: [How do I install different (upgrade or downgrade) PHP version in still supported Ubuntu release?
You could use a ppa to stay up-to-date with php. I use :
https://launchpad.net/~ondrej/+archive/php5 Launchpad logo
It's now on 5.4. If you want use this ppa do this:
ppa:ondrej/php5 Launchpad logo (Click here for instructions on using PPAs.)
sudo add-apt-repository ppa:ondrej/php5
sudo apt-get update
sudo apt-get upgrade
If you don't have add-apt-repository binary do the following:
sudo apt-get install python-software-properties
oerdnj
  • 7,940
[Seems outdated]
I you want to upgrade Ubuntu 10.04 LTS to PHP 5.3.10, this is how I have done it:
sudo apt-get remove --purge php*
sudo apt-get autoremove
sudo apt-add-repository ppa:brianmercer/php5
sudo apt-get update
sudo apt-get install php5 libapache2-mod-php5 php5-cli php5-cgi php5-mysql php5-gd
sudo service apache2 restart
sudo pecl uninstall apc
sudo pecl install apc
Thanks to Brian Mercer for his PPA for php5.
Just found how to upgrade to 5.3.5, maybe it will help you:
sudo add-apt-repository ppa:fabianarias/php5
sudo apt-get update
Thanks to http://blog.leenix.co.uk/2011/06/ubuntu-1004-lts-lucid-php-533-backport.html
$ php -v
PHP 5.3.5-1ubuntu7.2ppa1~lucid1 with Suhosin-Patch (cli) (built: May 25 2011 18:51:41)
Copyright (c) 1997-2009 The PHP Group
Zend Engine v2.3.0, Copyright (c) 1998-2010 Zend Technologies
Kostanos
  • 1,514
-1
check this: http://www.omaroid.com/installing-lamp-with-php-5-3-6-on-ubuntu-11-04-natty-narwhal/
Kev, The part that says: use this repository:
deb http://packages.dotdeb.org stable all
deb-src http://packages.dotdeb.org stable all
-2
Unfortunately I believe you have to install PHP from source in order to get the latest version. You can get the file from php.net, and essentially follow their installation guide from their manual.
