I have replaced windows with Ubuntu 14.04. My Windows was on drive c & I have formatted drive c with the Ubuntu but during the OS installation unknowingly I had assigned 105mb of swap memory, but now I want to increase my swap memory. I had checked many relevant questions & answers for this but did feed need. I don't have any unallocated space for this. My c drive is 137gb on which approximate 97 gb is free & on d drive I am having free space up to 25gb. Please let me know how I can increase my swap memory without causing any data loss.
Asked
Active
Viewed 1,073 times
You must decide which directory with enough space to create the swap file, you suppose is in /, (/swapfile).
Open a terminal,
Press Ctrl+Alt+T
Run it for 2 Gb (bs=2048):
sudo -i
dd if=/dev/zero of=/swapfile bs=2048 count=256k
mkswap /swapfile
swapon /swapfile
Now You can ensure that the swap is permanent by adding it to the fstab file.
Continue running in the terminal:
nano /etc/fstab
Change the line:
UUID=c9eb230e-ab85-4bc0-b24f-06caeac4d953 none swap sw 0 0
To:
/swapfile none swap sw 0 0
Ctrl + O, save file. Ctrl + X, close nano.
Continue running:
echo 10 | tee /proc/sys/vm/swappiness
echo vm.swappiness = 10 | tee -a /etc/sysctl.conf
chown root:root /swapfile
chmod 0600 /swapfile
reboot
That's all.
kyodake
- 17,808
Just copy paste the following line in terminal and it will create 2 GB of swap
sudo su
Then Copy Pate the following
mkdir /swap && cd /swap && fallocate -l 2g 2GB.swap && mkswap 2GB.swap && swapon 2GB.swap && echo "# # # Swap File # # #" >> /etc/fstab && echo "/swap/2GB.swap none swap sw 0 0" >> /etc/fstab && chmod 0600 2GB.swap && mount -a
Does it make sense to create swap partitions for new installations nowadways?
