64
I have a PDF file that was the result of the scan of a book.
In this file 2 pages of the book correspond to 1 in the PDF. So when I see a page in the PDF file I'm actually seeing 2 pages of the book.
(original)
I would like to know if there's any way to convert this file to another PDF where 1 page of the book corresponds to 1 page of the PDF i.e. the normal situation.
fossfreedom
  • 174,526
JGNog
  • 829
9 Answers9
73
You can use mutool, a MuPDF command-line tool (sudo apt-get install mupdf-tools):
mutool poster -x 2 input.pdf output.pdf
You can also use -y if you want to perform a vertical split.
Peque
  • 1,258
30
Try Gscan2pdf, which you can download from the Software Centre or which you can install from command line sudo apt-get install gscan2pdf.
Open Gscan2Pdf:
  1. file > import your PDF file;
    import
    Now you have a single page (see the left column):
    single
  2. then tools > Clean up;
    clean up
  3. select double as layout and #output pages as 2, then click OK;
    split
  4. Gscan2pdf splits your document (among other things, it will also clean it up and deskew it etc.) Now you have two pages:
    double
  5. Save your PDF file if you're satisfied with the result.
neydroydrec
  • 4,780
17
I would use Briss. It lets you select various regions of each page, each of which to turn into a new page.
frabjous
  • 6,601
Another option is ScanTailor. This program is particularly well suited to processing several scans at a time.
apt-get install scantailor
It unfortunately only works on image file inputs, but it's simple enough to convert a scanned PDF to a jpg. Here's a one-liner that I used for converting a whole directory of PDFs into jpgs. If a PDF has n pages, it makes n jpg files.
for f in ./*.pdf; do gs -q -dSAFER -dBATCH -dNOPAUSE -r300 -dGraphicsAlphaBits=4 -dTextAlphaBits=4 -sDEVICE=png16m "-sOutputFile=$f%02d.png" "$f" -c quit; done;
I had screenshots ready to share, but I don't have enough rep to post them.
ScanTailor outputs to tif, so if you want the files back in PDF you can use this to make a PDF for each page.
for f in ./*.tif; do tiff2pdf "$f" -o "$f".pdf -p letter -F; done;
Then you can use this one-liner, or an application like PDFShuffler to merge any or all files into one PDF.
gs -q -sPAPERSIZE=letter -dNOPAUSE -dBATCH -sDEVICE=pdfwrite -sOutputFile=output.pdf *.pdf
Curtis
  • 141
A command line solution using ImageMagick:
  1. Split the PDF into individual images, here at 300 dpi resolution:
  2. Split each page image into a left and right image:
     for file in page-*.png;
       do convert "$file" -crop 50%x100% "$file-split.png";
     done
  3. Rename the page-###-split-#.png files to just 001.png, 002.png etc.:
     ls page-*-split-*.png | cat -n |
       while read n f; do mv "$f" $(printf "%03d.png" $n); done
  4. Combine the resulting page images into a PDF again:
     convert [0-9][0-9][0-9].png result.pdf
Sources, variations and further tips:
tanius
  • 6,610
  • 42
  • 52
Here is a python script for this:
# Source http://stackoverflow.com/a/15741856/1301753
import copy import sys import math import pyPdf
def split_pages(src, dst): src_f = file(src, 'r+b') dst_f = file(dst, 'w+b')
input = pyPdf.PdfFileReader(src_f)
output = pyPdf.PdfFileWriter()
for i in range(input.getNumPages()):
    p = input.getPage(i)
    q = copy.copy(p)
    q.mediaBox = copy.copy(p.mediaBox)
    x1, x2 = p.mediaBox.lowerLeft
    x3, x4 = p.mediaBox.upperRight
    x1, x2 = math.floor(x1), math.floor(x2)
    x3, x4 = math.floor(x3), math.floor(x4)
    x5, x6 = math.floor(x3/2), math.floor(x4/2)
    if x3 > x4:
        # horizontal
        p.mediaBox.upperRight = (x5, x4)
        p.mediaBox.lowerLeft = (x1, x2)
        q.mediaBox.upperRight = (x3, x4)
        q.mediaBox.lowerLeft = (x5, x2)
    else:
        # vertical
        p.mediaBox.upperRight = (x3, x4)
        p.mediaBox.lowerLeft = (x1, x6)
        q.mediaBox.upperRight = (x3, x6)
        q.mediaBox.lowerLeft = (x1, x2)
    output.addPage(p)
    output.addPage(q)
output.write(dst_f)
src_f.close()
dst_f.close()
input_file=raw_input("Enter the original PDF file name :") output_file=raw_input("Enter the splitted PDF file name :")
split_pages(input_file,output_file)
I hold a copy of this on my personal github site...
andrew.46
  • 39,359
Sejda can do that either using its web interface or command line interface (open source). The task is called splitdownthemiddle
-1
You could use okular or any pdf reader and then use print to file and select options and copies-> pages . Select your interested pages and then give print. It will cut the selected pages . Simple and easy !!
-2
There is a wonderful program scankromsator. It is free and works quite well through wine. More information here.
oromay
