I got a HP 255 G2 laptop running Ubuntu 14.04 and I want to change the functionality of the F2,F3,F4,F6,F7,F8,F9,F10,F11 and F12 because F2 and F3 are used for changing the luminosity,the others are for volume,wireless switch on/off etc. so they are mostly useless and when I tried to install a UNIX Virtual machine,I had to press F12 and I just turned off the wifi or on Minecraft I couldn't save a seed or toggle view because of this...I'm sorry if it isn't the right site to ask this but I thought that maybe the operating system matters.
Asked
Active
Viewed 423 times
Sure you can ask this question on this site. :)
You can do this:
1. Open up System Settings.
2. Choose Keyboard.
3. Go to the tab Shortcuts.
4. Remove any shortcuts you do not want.
This may not work for the WiFi key though.
EDIT
You could also try seeing if there's an option in the BIOS to change them. When you start your computer, at the very first screen where it says your manufacturer logo (HP), it should say something like F2 to enter setup. Press F2 at that time and it should take you into BIOS (which is a fancy name for the hardware options of your computer). There might be some options in there to disable fn keys.
GreenRaccoon23
- 161
