I need some help about installing Ubuntu onto my friend's Dell Dimension DM061 desktop PC, which is currently running Windows Vista.
It seems to have an Intel dual core CPU and plenty of free space on the hard drive. Unfortunately, I soon found out that I couldn't attempt to install the 64 bit Ubuntu 14.10 version from the Linux Format Christmas 2014 issue, because at least 2 GB RAM is required, but his PC only has 1 GB RAM.
I have now failed in my first installation attempt, because I was required to burn an ISO image onto a DVD, but there are no blank DVDs here. I've got a USB memory stick, but I don't know if or how I can use that instead.
At the moment, I've got a live version of Fedora Linux installed onto the USB stick and have managed to boot my friend's Dell Dimension desktop PC from that stick.
What should I try next to try and install Ubuntu onto this PC?
Thanks for all your suggestions. Today (Sunday) I'll see if I can buy a blank DVD or even a blank CD from anywhere. I'll also wipe Fedora Linux live version from my USB memory stick then try to burn an ISO image onto that for installation. I read on the Linux Format magazine Christmas DVD that I could install an image onto a USB stick using something called dd , but unfortunately I've never even heard of dd before, let alone used it. The main thing is that I've now got about 24 hours left to install Linux onto my friend's PC. I've only been here once before, 16 months ago, and I don't know if or when I'll ever come back. I mentioned in the title that he's technophobic, which is actually a bit of an understatement. He is totally incapable of installing any extra RAM, or unplugging or installing a hard drive, and he couldn't even tell me which version of Windows he was running. I told him that it must display the version on the monitor when he boots up or closes down, but while I've been here I've seen he leaves the PC turned on all day. I found out which version of Windows it was when the screen saver was displayed. To sum up, unless I install Linux for him, then he will never be able to install it. It took me 5 days to get onto his WiFi network, because the hub/router with the password printed on it was buried somewhere in the room. I also wanted to show him my Raspberry Pi computer which I use a phono to SCART cable with, but he claims that if I plugged it into his TV it would blow up. There is no other TV here which is working and has a SCART socket. I haven't got round to buying an HDMI to VGA cable for it yet. This costs about £6 on eBay, but about £45 in Maplins. Even if I had one, I doubt I could unplug the monitor cable from the PC and connect it, because the room is in such a mess. I hope someone can make a few more suggestions in the light of all this.
